k27 upgrade
turbocar
k27 upgrade
Post by turbocar »
What are my options on a k27 upgrade? I assume somebody makes something more modern.
Mark 88/M5 Houston
Post by Mark 88/M5 Houston »
From the Turbo Charging Dynamics Web Page: 745i upgrades
k27-60 Hybrid Turbo
Name: k27-60 Hybrid Turbo
Description: Rebuilt k27 featuring Garrett 60 trim compressor wheel. The k27 is extensively modified to accept the 60 trim wheel. This combination will support 480rwhp. $200 core charge.
Price: $799.00
Shipping Weight: 20
http://www.turbochargingdynamics.com/pr ... _Turbo.php
turbocar
Post by turbocar »
Why is that one turbo in a section by itself? What about the stage 4 turbo that is $50 cheaper and makes more power?
turbodan
Post by turbodan »
The turbine flanges are not interchangeable. The Stage 4 turbo fits the TCD manifold. The K27 upgrade is for those that choose to retain the 745i manifold.
M. Holtmeier
Post by M. Holtmeier »
When I had the factory turbo on my 745i fail, I went to Todd for the upgraded k27. He made me a very generous offer on an entire upgrade kit for the car. Knowing the limitations of the k27, I opted for the kit.
turbocar
Post by turbocar »
Is there any other options or just that one turbo if I want to keep my manifolds?
clongo
Post by clongo »
You could build a adapter plate and use any turbo you want. But you will also need a new downpipe.
turbodan
Post by turbodan »
If there is room that can work. Makes packagine even more difficult. The 745i manifold itself would still present a restriction. It could possibly be made to work more efficiently with porting. I know I was able to open up my old 524td manifold substantially.
Lucas_Roehr
Post by Lucas_Roehr »
:hijack:
Thread jack and revival...
So is the upgraded k27 worth while? I'm not experienced in reading compressor maps, but how does it compare to stock? And how does it compare to the stage 4 TCD?
clongo
Post by clongo »
I'm about to have my upgraded k27 up and running in a week. I can report back how it compared to the stock K27. You can't really compare it to the stage 4 turbo. It uses a better manifold and that turbo is still 25 years newer.
Lucas_Roehr
I think you can compare it. Its not apples to oranges, Its more like fugi apples to granny apples. Very different, but still apples.
Hit Man X
Post by Hit Man X »
turbocar wrote:Is there any other options or just that one turbo if I want to keep my manifolds?
Miller up in Canada used to modify T4 flanged turbochargers (Precision based) with a custom plate welded to the turbine housing to fit the 745i/K27 manifold.
I have one sitting in my attic, if anyone is interested in seeing it let me know and I will post some pictures. From what I recall it has a 60mm inducer on the cold side, journal bearing, and around a 0.60 A/R
europartconnect
Post by europartconnect »
Thanks for getting this info as i was interested in this also.
charofire
Post by charofire »
Does anyone know the A/R's of the compressor housing and turbine housing of the kkk27?
marc79euro645
Post by marc79euro645 »
I worked this out a while back.
k27
turbine 66mm
a/r 0.90
trim 86
compressor
48mm
trim 40
a/r = 0.7
I think these are right
good luck
marc
marc79euro645
correction compressor a/r=0.64
