Hairspray, better clamps, removing the powder coat or ?
Post by Coldswede »
What is the best way to keep these two from coming apart?
Besides me keeping my foot out of it that is!
Martin in BellevueWA
Post by Martin in BellevueWA »
Fabricate aluminum pipe with beads to hold the couplings. I ended up with a band saw and bench sander piecing bends & reducers together. There's an older guy in Redmond that welds aluminum. You can place the recirculation bypass valve where you want it & make things tidy. I have only 3 couplings for my charge pipe & they don't pop anymore; the idle control valve is better spaced too. I also redid the intake pipe from the maf to the turbo; miller's pipe was 5" wide & hit both the engine & the frame. Customizing aluminum pipe this way is pretty fun, and you can drink beers in the garage.
The couple hundred dollars for the sander, band saw & aluminum, and ~ $45/hr for the welding are much cheaper than any shop.
clongo
Post by clongo »
Did you pick up another project? I don't remember you having a green car.
I had good luck with quality clamps and some hairspray to keep my old charge pipe setup together. I'm using tbolt clamps now and haven't had a issue.
turbodan
Post by turbodan »
You can roll the end of the red pipe over to create a bead. I just weld a small bead around the ends of pipes, but that would destroy the purty finish. It doesn't even need to go all the way around. About an inch of bead every 120 degrees around would be sufficient.
thespeedfactory
Post by thespeedfactory »
Take the red pipe to a mahine shop and have them flare the end or bead roll.
Many shops have a bead roller or a hydraulic flare machine.
Then get T-bolt clamps.
T_C_D
Post by T_C_D »
That stock bellow must be rock hard by now! Good job getting it running!
Post by Coldswede »
T_C_D wrote:That stock bellow must be rock hard by now! Good job getting it running!
Thanks, it runs like a screaming raped ape actually! :laugh:
Bellow is newer and not hard.
Thanks everyone, I think there were some very good answers to the question.
He did not sell that car, did he? :shock:
Post by Coldswede »
No Chris, I'm just helping him with it.
That is an insanely cool car. Not another one like it on the planet. Good luck to both of you!
Bead roll, hairspray and a t-bolt clamp.
Coldswede, is there a build thread somewhere I missed? :dunno:
Brad D. wrote:Bead roll, hairspray and a t-bolt clamp.
Suspenders and a belt.
clongo
Post by clongo »
Nebraska_e28 wrote:Coldswede, is there a build thread somewhere I missed? :dunno:
I'm wondering the same thing. We need moar infoz!!!!
Post by Coldswede »
It has been well documented here:
http://www.mye28.com/viewtopic.php?t=70338
And yes it is at least as nice as it looks in the pics!
Hit Man X
Post by Hit Man X »
This.
Exact same thing I do on my 6.4 PSD.
demetk
Post by demetk »
Exhaust pipe and brackets welded to them to secure them.
DangerWillRbnsn
Post by DangerWillRbnsn »
Interesting... any reason you run no IC? I have a stock 745 IC for my setup, and wondering if it's a waste of time to mount and plumb it in.
