Dyno time again!
Dyno time again!
Heading over in about 15min. Hoping this new setup put's down some decent #'s. Here is a thread from the last time I was at the dyno.
http://www.mye28.com/viewtopic.php?t=95 ... light=dyno
I am now running a upgraded 745i turbo, A/W intercooler, custom downpipe with wastegate recirc, 50lb injector's, PF tuning MS2 extra with EBC, ARP headstuds, MLS HG, 15psi. I will post dyno charts and datalog's shortly after. Wish me luck!
Re: Dyno time again!
It's always nerve racking. Will they let you operate the car on the dyno?.......they won't here. That REALLY bugs me.clongo wrote:Wish me luck!
- Beamter
- Beamter
- Beamter
Figuring out why my car run's like crap now.9mil wrote:Hells yea- that makes my pants all tight!
Congrats on the good #s.... What's next?
While on the dyno my laptop died because I didn't see the battery warning. I'm running a dell mini 9 so I have my bottom status bar set to dissapear so I have more room on the screen for TS. We had the car turned on when the laptop died but it wasn't running. I plug the laptop in and let the car sit for about 30 min to cool off. Hope back in the car, and it run's like garbage. Whenever I give it throttle it goes way lean and wants to die for about 2 seconds. If i'm cruising in gear it runs fine, but any throttle response makes it go way lean for a second.
I tried reflashing firmware this morning. Unfortunately that didn't work. I'm not sure if its a TS issue or something mechanical and its a bad coincidence. I just find it very odd that before the laptop died everything was running perfect and after It run's like crap. Any advice from the MS experts? I took a datalog this morning and will post it up.
I haven't had a chance to check for vacuum leaks yet either. I got home around 1am this morning and am at work now. Again, any advice would be greatly appreciated.
2012-11-15_07.55.12.msl
Here is the datalog. I was giving it throttle while cruising to show how it goes way lean.
- Beamter
Did you lose the TPS signal or sensor?clongo wrote: Whenever I give it throttle it goes way lean and almost dies for a second. Doesn't matter if its at idle or while cruising in any gear.
- Beamter
