Dieselboost's 524compoundTD
no-smoke-no-poke
Post by no-smoke-no-poke »
and why are the regular MLS gaskets coming as 2.3mm compared to the stock 1.87mm. why such a difference, does the comp ration get too high?
DieselBoost
Post by DieselBoost »
no-smoke-no-poke wrote:and why are the regular MLS gaskets coming as 2.3mm compared to the stock 1.87mm. why such a difference, does the comp ration get too high?
it depends lot of which kind of engine you are building...
if compression rate is lower than stock... you can use higher higher boost... like over 2.5bar
and this helps a lot with cylinder head flowing...
we measured that m21 cylinder head flows about 145hp in stock condition... but my head flows about 250hp easily now...
but main reason to your question is that i had no choice... my friend had one spare mls gasket and it was that...
DieselBoost
Well while im working with my own car... i has other projects too
for other people...
im doing 1988 ford mustang for one racing team where im planned to race with it...
but really interesting project is what im doing for my friend...
Nissan cedric turbodiesel with ld28 ;)
DieselBoost
Super sizing the fuel lines...
im doing my new fuel lines...
inner diameter is now 9mm from tank to injection pump...
just noticed that injection pump has 6mm connector....
now it has 9mm connector...
DieselBoost
Just got ready engine room section electrics...
NO more shitty wires etc...
now engine room needs only paint job for boost pipes, finishing for the fuel lines etc...
after these mods i will bolt on my bodykit and beige leather seats
after all this... i will make real photoshooting with my friend who is professional Photographer.
but i say... car is not made with with big money today... and it is not show car... it is just made for fun and weekend fighter and actually for daily usage in summer...
so there are few not so cool thing in it...
:lol:
DieselBoost
Ok.
I got some sandblasting operations today...
i blasted few work project parts and in same session i blasted boostpipes for my car... before that i grinded welding joints from boostpipes...
after that i painted those with black urethane paint...
tomorow i will paint those with silver wheel paint (no spray paint)
maybe soon i will fit the bodykit
DieselBoost
Nice... my fuel system works now... little bit finishing and it is ready...
it seems that my car will run at evening tomorrow
Alleslowbuged
Post by Alleslowbuged »
cool :D
DieselBoost
HELL YEAH!!!!!!!
Its running again...
and fuel system works better that i thought...
+ my new electrics too :P
Pipewelder
Post by Pipewelder »
I have now read this whole thread and also checked out all of your pictures in the eyecandy section. Very nice project and car i must say! Looks almost like my 524td, same paintcode and then i've even got a set of Breyton magic 19" rims that looks almost like yours except from the "splitwheel bolts". :shock: :D
I have a similar project going on with my car, but don't worry it will be repainted in another colour and use other rims. ;)
Maybe i will put up a project thread in here later on.
Jelmer538i
Post by Jelmer538i »
@Pipewelder: Please post up your project! I really like the idea of these High power diesels!
DieselBoost
Pipewelder wrote:I have now read this whole thread and also checked out all of your pictures in the eyecandy section. Very nice project and car i must say! Looks almost like my 524td, same paintcode and then i've even got a set of Breyton magic 19" rims that looks almost like yours except from the "splitwheel bolts". :shock: :D
Haha... nice.... :)
Pipewelder
I'm very curious on how your new fuelsystem works. :) That's one thing that has annoyed me for long time, the stock filtering when there is airbubbles.
Update us! :D
And Jelmer538i: I'll try to get up a project thread soon. I really love the 524td's and it's real nice to see that there are serious people tuning these wonderful cars! ;)
DieselBoost
Pipewelder wrote:I'm very curious on how your new fuelsystem works. :) That's one thing that has annoyed me for long time, the stock filtering when there is airbubbles.
Update us! :D
it really works... i have tested it littlebit... no air bubbles anymore...
need to check my fuel pressure when i get gauge on it...
i will report later when i know more...
DieselBoost
Hell yeah... car is inspected now... and taken to road use...
just cruised about 150km today!!
everything works just how i wanted, boost is 0.5bar but later i will use 2.5bar...
DieselBoost
Hell yeah!!! i DID IT!
we got an leaky mls gasket.... with daily driving and 1bar boost
i think this is caused by failure in bloc deck surface... or leak between layers of mls gasket... which i dont glued...
Pipewelder
Congrats! Or what should i say.. :D It sounds like the issue depends on either block or cylinderhead surface. What i've heard the MLS gaskets requires very good surface finish to work. Some poeple says that you have to glue, and some says you don't have to. But the surface finish is quite important to get it seal properly. This by experiences on gasser engines, but the same should apply for the diesel, if not more important than gas engine.
DieselBoost
i have some ideas about this...
my cylinderhead was better than new one... and never used...
but that block or.... hard studs caused this by aluminum head thermal expansion...
and i used vht copper gasket glue... that i always use...
mls gasket with elastomer doesnt need glue...
DieselBoost
Little bit offtopic... BUT...
Awesome movie about supercharged mustang svt cobra...
Built by me and my friend... under name of Hakala Performance for our customer and friend Mika
http://youtu.be/ewN8pb_FQyU
Mika and Harri are attempting to gumball 3000 in this summer... with authentic 67 shelby gt500 car is fully matching numbers restored... by our workshop for Mika of course
http://www.shelby67.com/
Badger
Post by Badger »
there is some good info in the turbo section about MLS gaskets. I'm sure you know what your doing because your work looks good. A lot of guys had leaks when the surface of the head and block weren't at a mirror finish.
DieselBoost
[quote="Badger"A lot of guys had leaks when the surface of the head and block weren't at a mirror finish.[/quote]
yep... that is irritating to know :x
DieselBoost
Holy moly... i just found that crank bearings and connecting rod bearings and piston ring are not so expensive what i thought...
so i say hell yea... i will get my fully machined flame ring block from storage!
DieselBoost
just got cyl head back on place...
i cleaned old mls gasket surfaces and glued it between the layers...
tomorow i will do some tests... hope it will work
DieselBoost
It works again...
http://youtu.be/n2oMz2FZASM
Alleslowbuged
cool :D
Can you write some more details, about what you have done to bring it back on the streets?
DieselBoost
yes... i cleaned old mls gasket and glued it properly... and then i put all back to my car :laugh:
so now it works again...
just came home.... cruised about 6 hours...
and with lot of boost.... and yep... it burns rubber too :)
Alleslowbuged
Hi,
what did you use as glue? As i wrote i also have had my car running like a steam lokomotive since my last cylinderhead repair. I did not pull the cylinderhead, i only loose a cylinderhead bolt, put them out, cleam then, put new anty seeze on them and torque then down again properly and then the next bolt and the next bolt and so on. Since then my car runs without leaking, but i only run with stock boost pressure and did not put so much load on the engine.
Best Regards
DieselBoost
I used vht copper gasket cement...
i modified little bit cooling system...
-deleted that cold circulation from head...
i drilled 3 3mm holes to thermostat...
i will re torque my head soon... just in case
Alleslowbuged
DieselBoost wrote:I used vht copper gasket cement...
Hi, what did you mean with "deleted the cold circulation from head"? From what you write, i think you still have a working thermostat, so you still should have short and long circuit. Did you mean the short circuit to the cold start valve from the injection pump (i have dismount this for serveral year now and do not miss it)?
Good to hear that your car is finaly running now.
Best Regards
Alleslowbuged
DieselBoost
i never used that valve... even in my first engine...
and yes i has working thermostat... with holes...
but i mean this...
http://e28-535i.com/upload/IMG_9567.JPG
