M30 Turbo Injectors
M30 Turbo Injectors
http://www.siemensdeka.com/product/60lb ... -fi114962/
I'm considering injectors at this point in my m30 turbo build. It's going to be running 20lbs of boost steady. I will be running megasquirt and don't want to sacrifice idle as is common with large lb injectors. Do the injectors in the link look good or is there something better? Don't want to spend more than say $60/injector.
You need to not get the short style.
60lb is too small.
These 80lb are $47 each.
If I wasn't injecting alcohol through an 83lb/min nozzle
they would be close to "100%" dc on mine m30.
Not much more boost then what you're wanting either.
This is not 1971 "big" injectors idle like butter.
80lbs are only pups.
http://www.ebay.com/itm/SIEMENS-DEKA-80 ... 5b&vxp=mtr
Do the right thing.
60lb is too small.
Do the right thing.
