My turbo car / mosquito control device
So before vintage I did some work on my 5er, which included building a shroud for my K&N, I think the shroud was a bit too tight. That, and my K&N was always a bit crushed and hadn't been cleaned in a while.
On the way down to the show the car belched oil smoke from the exhaust a few times, but ran well. I daily drove it a few weeks afterwards and the smoke got worse.
It sat for a while and I finally pulled it apart to find the K&N totally collapsed, definitely restricting airflow.
Is it likely that the vacuum in the intake was pulling oil past the seal?
I've since replaced the filter, but the car is still belching smoke, especially at idle, only when the engine is warmed up. Those driving behind me say they can smell oil even at speed. I had hoped that it was just oil pooled up in the exhaust burning off, but i'm not sure anymore.
I pulled the drain hose from the turbo while it's running and it seems to be draining well.
Any other ideas before I pull the turbo and send it off to be checked or worse, start doubting my rings?
So what is it that does the leaking? In my brief research the center section is basically an oil lubricated / cooled plain bearing with two slinger rings and a circlip like ring.
I have no idea if this is coincidence but I used to run Redline 15w50 and literally the day this happened I pumped some Liquimoly into it because I was out of redline.
The one journal bearing turbo I ever used lost the turbine side oil seal. Very slight amount of oil burn at idle and cruise and a big-ass cloud when you spool it up.
Every other turbo I've run was a GT series ball bearing unit, and I've had zero failures with those. They cost more initially but at least thats the end of it.
- Beamter
- Beamter
In case anyone is interested…
I did a differential compression test today, the results were surprisingly good for a motor that has been FI for years and has suffered much detonation under my MS regime. A few of the cylinders had a slight amount of what I think is valve seal noise I could hear through the oil cap, but not bad. The lowest cylinder was 78/80 hot.
The smoke is in my opinion caused by one of the following, placed in order of probability.
1. Worn turbo seals pushing oil into the exhaust
2. Worn valve seals
3. Worn oil rings
I am going to upgrade to a ball bearing turbo. If it still smokes i'm going to take the engine apart, redo the internals, redo the head and install an MLS gasket and studs.
Basically win win.
2. Worn valve seals
3. Worn oil rings
Basically win win.
Leakdown through the crankcase is rings. Leakdown through the valves is going to be evident from the intake or exhaust. Its not likely you'll actually hear valve leakage through the oil filler cap. Might be easier to confirm where its actually going with a smoke source.Patrick McHugh wrote:In case anyone is interested…
2. Worn valve seals
3. Worn oil rings
Basically win win.
I'll know soon… The engine is on a stand in my shop and is getting torn down tomorrow!turbodan wrote:Leakdown through the crankcase is rings. Leakdown through the valves is going to be evident from the intake or exhaust. Its not likely you'll actually hear valve leakage through the oil filler cap. Might be easier to confirm where its actually going with a smoke source.Patrick McHugh wrote:In case anyone is interested…
2. Worn valve seals
3. Worn oil rings
Basically win win.
How would I have used the smoke machine to find the leakage? Pressurize the cylinders with smoke somehow?
- Beamter
Well, she's out and in a billion pieces!
The exhaust valves look dry and the cylinder walls still show cross hatching (despite 10 years of FI abuse), I'll know more when I pull the crank and pistons, but I think the oil was leaking from the turbo.
The rotor was super loose, lots of play.
I'm still stoked I pulled it, Todd shipping me some goodies!
