Clutches
Clutches
OK, I'm nearing a point in my build where I'm looking for a clutch, that's going to hold. Worse case scenario I can take a Tilton and get a flywheel machined. What is currently available for the M30 that is going to be actually capable of hold 600 ft-lbs? Everything I've been able to find has been in the 400 range and I'm not wanting to buy something that will just give up the ghost on me after a few passes down the track.
Re: Clutches
Get to work on a Tilton.
Re: Clutches
I like mine from clutch master.
Re: Clutches
Honestly I bet clutchmasters would build something strong enough. I have a FX-300 which isn't up to what you're asking but I know they offer stronger clutches. Shoot Todd a PM see if he can get clutchmasters to build something strong enough.
Re: Clutches
I doubt any single disc clutch will hold 600rwhp. Maybe 600bhp. I can quote you a twin disc.
Re: Clutches
Aren't they rated at torque though?
Re: Clutches
Wow , I missed the 600 hp somehow.
What about the rest of the drivetrain?
I destroyed a driveshaft punching the clutch with only 350hp.
Re: Clutches
This is probably the best single disc combo, but only takes around 530ft-lbs
http://shop.klracing.se/sv/artiklar/sac ... 5-e34.html
http://shop.klracing.se/sv/artiklar/bmw ... -puck.html
Here you can pick parts for 2-3 disc setup:
http://shop.klracing.se/sv/artiklar/dri ... index.html
This twin disc setup takes close to 600ft-lbs but is quite expensive but comes with a machined flywheel.
http://ezrsjdm.rallybazar.sk/index.php? ... 8&Itemid=3
Re: Clutches
530tq rated is all you need.
Even at 500tq @ 7,000rpm redline is 666hp
520tq @ 6,500rpm is 643hp.
Re: Clutches
My brothers S38 turbo has a Southbend clutch and that holds 650lb/ft just fine! You need a strong leg though.....
