Does anyone know the specs for the valve cover nuts on the m21? are they the same as the m50/m52? The recessed studs are intact but I am missing all four nuts thank to the previous owner. I have not been able to find the specs anywhere.
D28
Valve Cover Nuts
Re: Valve Cover Nuts
From what RealOEM indicates, it seems they are unique to the M21:
https://www.realoem.com/bmw/enUS/part?i ... 1121284244
They appear to be fairly readily available, however:
https://www.fcpeuro.com/products/bmw-ca ... 1121284244
http://www.pelicanparts.com/More_Info/1 ... 84-244-BOE
Why do you need special nuts for the valve cover?
Thanks shriekback! I hadn't thought of checking realOEM. Mustve slipped my mind. And yes the valve cover has recessed studs so the nuts have a long threaded section that extends down into the valve gallery. Im sure there is a name for this type of fastener but I have no idea what it is.
