Hello:
I'm replacing the insulation under the car that runs above the exhaust and below the transmission tunnel. Part #1 as show here:
https://www.realoem.com/bmw/enUS/showpa ... 1481875998
Is the orientation in the diagram correct in that the "V" cutout in the piece is toward the back of the car ? I cant seem to get the factory holes in the insulation to line up to the mounting speed nut studs under the car. Easy enough to create a new hole in the part I suppose, but I thought I would ask first.
TIA
Exhaust Heat insulation orientation
Re: Exhaust Heat insulation orientation
The diagram appears correct.
e24 from the web:
https://www.bing.com/images/search?view ... 11&iss=VSI
e24 from the web:
IIRC that Vee is so it doesn't rub on the driveshaft.
Well, Im not sure what to say but when I installed the shield with the V toward the front of the car, the holes in the part lined right up with the speed nut studs under the car.
Well, the V split definitely goes to the rear:
Because when you get the exhaust in, the square end needs to be in front:
First off, your car looks very clean! I hope to get mine looking as good someday. Looks like you replaced your speed nuts. May I ask where you found them ?
Here are photos of what Im dealing with. My middle stud doesnt line up with the factory holes in the heat shield. Easy enough to create new ones I supposed, but this is strange.
Front:
https://share.icloud.com/photos/0bbEXmX ... BL_f0OEk5Q
Middle
https://share.icloud.com/photos/042ICN9 ... ahITjvUWVw
Rear
https://share.icloud.com/photos/095fCSf ... 6RGhNSuJkQ
Front:
Middle
Rear
Those are just large fender washers with regular M6(?) nuts (pretty sure they might be nylock nuts); I likely bought them at Belmetric.
Not seeing your overall pictures of the heat shield, but one thought is that it's just distorted somewhat. The piece is very malleable and soft and is kind of prone to getting out of it's proper shape. That could lead it to not align to the mounting studs. I would try massaging it a little and see if you get the holes closer to the studs. I had to fix mine when I unpacked it from the supplier, it was kind of dented and bent with a lot of wrinkles in it. You kind of have to flatten it a bit which pushes the edges out, that gets the holes closer if I recall.
That clean undercarriage cost me a lot of brain cells, just look it up in my build thread. Those pictures are also 9 years old so I can say it doesn't look that clean anymore. But thanks for the compliment!
Yes on both and an odd curiosity is the washers are stainless.vinceg101 wrote: Dec 13, 2024 2:44 AM Those are just large fender washers with regular M6(?) nuts (pretty sure they might be nylock nuts)
Well, these are just yellow zinc steel as are the nuts (although SS would make more sense).
