Dieselboost's 524compoundTD
hello again.
new project pics here.
http://irc-galleria.net/archive.php?nic ... id=2662987
i tested, how new parts fit in. not final position as you can see.
engine in pics is old "water-drinker" and im working it to get it out from car.
there is allso old exhaust manifold and inlett.
oh, i forgett, the carage is new and im very happy with it
this is nothing to do with diesels or even bmw:s but i love this car.
http://www.youtube.com/watch?v=cA8ouFf_NVI
What offsets will you be running?DieselBoost wrote:ok, my new tyres arrived.
rear tyres. nokian-tyres 255/40r17
front tyres. nokian-tyres 215/40r17
heh its going wild to fit those giants to my car.
i must get new rims, i i will buy keskin kt1 rims
rear 10"
front 8.5"
maybe mk2 golf rear fenders will help with those.
ok. my intake manifold is ready,
i just modify the old one.
pictures. http://www.mye28.com/viewtopic.php?t=57130
pump is going to this workshop www.ppdiesel.com
i dont know all.
what i know there is gonna be 12mm fluidhead(i dont know the english word)
and something to äähh..
this http://www.netikka.net/vepiku/viritys/PICT3727.jpg
that is only selfmaded modification in picture by some guy.
i dont know all.
in the past, few people asked me. how large is combustion chamber of td-engine... so here is it.
http://e28-535i.com/upload/mye28.jpg
pics of cylinderhead in here....
http://e28-535i.com/upload/1_39.jpg
http://e28-535i.com/upload/2_34.jpg
better pics later...
intake flows 272 in 13.5mm lift, in 13mm lift 260 and 11mm lift 228.
exhaust flows in 11mm lift 133 and 13mm lift 133.
intake valve is 38mm (stock 35mm)
exhaust valve is 34mm (stock 31mm)
these measurements are done with non turbo use sucktion flowing meter.
so in turbo use it flows much better
valves are bigger than original and exhaust seats are 2mm bigger too.
valves are stainless steel.
Dear Dieselboost,
looks like a nice project. I have just restart my E28 524 again.
What is your goal for hp and torque, my one has 200hp and 380Nm in the actual setup, still using a 10mm hp plunger in the injection pump. I have also work on the cylinder head but use stock valves. With your 12mm injection pump and the bigges valves you should be able to to make 250hp+.
Here are some pics from my car, i have build a similar intake like yours, but designed as dual plenum intake. Did you think about using a NA intake as basis, this should flow much better than our strange designed turbo intake. I have allready bought a NA intake, but work in my golf mk1 in the moment, so this evolution has to wait a while.
http://s702.photobucket.com/albums/ww24 ... /524%20td/
Good look for your project, i will keep my eyes here.
Here are a link with dyno run results from another E28 forum:
http://www.e28-forum.de/forum/forum_entry.php?id=219139
Best Regards
Alleslowbuged
Best Regards
Alleslowbuged
i will post new pics when my head gasket and bolt operation is readyAlleslowbuged wrote:Dear Dieselboost,
Best Regards
Alleslowbuged
i hope we can get over 300bhp and 600nm
Dear Dieselboost,
huge numbers but with the 12mm plunger realistic in my eyes.
What type of headgasket will you use? I have a custom mls headgasket, from thailand, which is available in every thickness you wand. If you wand the contact, please contact me. Becuase i have send my stock gasket as template, you can bus just as a stock gasket.
I can also give you a contact for ARP bolts, if you not allready have some.
Best Regards, Alleslowbuged
I would be very happy to see 300hp in your car, would be a good goal for me.
having fun with couple of my friends, car is not my but our cars colour is allmost same.
http://www.youtube.com/watch?v=SR6kEb4M ... annel_page
