Evap and MS
jim325
Evap and MS
Post by jim325 »
What is everybody doing with the fuel line that goes to the charcoal canister then to the intake manifold.
I was thinking putting a 1 way check valve in the line and route it to intake manifold so it's sucking vapors pretty much all the time.
Can MS control an evap purge solenoid easily? MS2
Lurker27
Post by Lurker27 »
Plugged at manifold, tank open to atmosphere
MS can control evap solenoids etc but it's such a pain
FirstFives Dictator
Re: Evap and MS
Post by FirstFives Dictator »
jim325 wrote:What is everybody doing with the fuel line that goes to the charcoal canister then to the intake manifold.
Yours is wired to control it; I can help you with the settings.
Or you can use that output for boost control.
