preparing for boost
Blackey1693
preparing for boost
Post by Blackey1693 »
Just picked up an 85 535i parts car with a running motor that I'm swapping into my 83 533i (b33 motor is for sale) and I plan on boosting the b35 motor.....where do i even start? As nice as the TCD kits are, I'm not looking to get one, I'd rather build my own set up, I just don't even know where to start.
alijonny
Re: preparing for boost
Post by alijonny »
Blackey1693 wrote:Just picked up an 85 535i parts car with a running motor that I'm swapping into my 83 533i (b33 motor is for sale) and I plan on boosting the b35 motor.....where do i even start? As nice as the TCD kits are, I'm not looking to get one, I'd rather build my own set up, I just don't even know where to start.
You bought a 1985 535i with a B35 swapped in?
clongo
Post by clongo »
If its a stock E28 535i motor its a B34. Swap over the engine and electronics as they play better with boosted cars than the motronic 1.3 DME.
Do yourself a favor and buy the TCD kit. It will save you a lot of time and $$$ in the long run. Unless you have a lot of fabrication skills, equipment, and time.
T_C_D
Post by T_C_D »
You have had 10 months to research and you still have no idea where to start?
http://www.mye28.com/viewtopic.php?p=86 ... ht=#862341
clongo
Post by clongo »
We have had way too many of these noob threads lately.... Read the faq sticky and search on the forum. It's that simple.
marc79euro645
Post by marc79euro645 »
tcd kits are sweet, 745 manifold is another option,custom down pipe to existing cast manifolds are another option, or custom tube header. I picked up a 745 donor car for $400, but 745 setups are limited to 325-350 hp range.
tcd ftw.
good luck
marc
Ken H.
Post by Ken H. »
"preparing for boost."
a pair of amyl nitrite snappers as part of the anal sex episode?
Post by Coldswede »
I think the OP started the right thread to get "Boosted"! :cool:
Kenny
Post by Kenny »
Do you know how to weld?
If you want to build it yourself, that is probably the first question to ask...
Xenocide
Post by Xenocide »
Building manifolds can be pretty tough. You can probably hack some shit together and get the car to build boost, but you'll likely run into clearance issues and performance will not be nearly what it could be with a well engineered solution. Otis (Good n Tight on this board) and Todd (T_C_D on this board) have got their shit figured out. You're going to pay more, but it's a proven product.
The manifold is just a small part of a turbo system, you have a bunch more reading and learning to do, even if you do want to buy a kit.
Chebby engine is much cheaper.
Xenocide
Post by Xenocide »
Duke wrote:Chebby engine is much cheaper.
Well, you can talk to Todd about that too ;) :lol:
Lurker27
Post by Lurker27 »
Murfinator
Post by Murfinator »
Let me help. Here's where you start: http://www.mye28.com/viewtopic.php?t=98809
Use your tax return wisely. :up:
Shadow
Post by Shadow »
Well there you go.
