Let's set my car aside for the moment, Todd. The vast majority of the people on this forum, and those that do FI in particular, live at low elevations. That being said, being able to make a well-reasoned determination of what kind of power outputs will work and how that influences component selection has a great deal of relevance.T_C_D wrote:Ken,
The fact is that your car doesn't drive around with SAE corrected HP and therefore all your mention of it in a comparison manner for reliability, clutch capacity, etc isn't relevant. What was the uncorrected rwtq? 440/450ish?
Todd
Power losses at altitude are a fact of life, but that environmental constraint is a level playing field. Conversely, bring one of your builds up to Mile High and do the pulls. I can assure you that the printouts will indicate far less power than you got in the Midwest or on the Eastern Seaboard. Does this mean the components you used are incorrect, or that something's changed where reliability is involved?
Once again, the SAE corrections are applied to allow meaningful comparisons between tests conducted under differing conditions.
Back to my motor. Uncorrected power at the rollers with boost at 7.25 is somewhere around 465.
For your reading enjoyment, you can bring up the not2fast turbo calculator and input the relevant variables for my motor. Bring up the model and PM me for the numbers you will need. That model generates a fwhp value of 578 hp. This with an altitude input of 5328' ASL. Reset that altitude to zero (sea level) and the fwhp # is 663. No other changes.
My experience with the n2f model is it tends to be a bit optimistic, but the computational errors seem to be consistent over a large number of simulations. So not using a rubber yardstick here.
As to what happens with the outputs at lower elevations. While the car lives at a bit above 6000'ASL, it has been driven at sea level--the Cali Central Valley to be specific. I am here to tell you that at sea level it will rip off your bawlz and use them for castanets. This was with boost @ 7.25. Full boost was simply stupid.
