What clutch are you using?
Shadow
Post by Shadow »
You might be right.
But I replaced both tranny and motor seals.
Sometimes it would slip on the freeway when I put it in 4th at low rpm and just floor it. Only made 420tq at 19psi before the injectors cut out at 5.5k.
turbodan
Post by turbodan »
Did you put it in with a new flywheel?
Shadow
Post by Shadow »
Resurfaced with the same step up.
It's starting to grab alittle better now after some easy miles.
DieselBoost
Post by DieselBoost »
Clutch setup 240mm sachs racing "m5" with stock plate
my friend uses 228mm sachs racing "m3" with stock plate
quite cheap stiff setup...
no problems yet with our diesels
