745 boost
Ken H.
Post by Ken H. »
Golosok wrote:
Jeremy wrote:Dan, I noticed that too. Forget the pressure, I wonder what his IAT and EGT figures are. They've got to be obscene, even a larger than stock intercooler can't effectively cool a charge being created by a turbo running as hard as it can. :shock:
EGT never went pass 850 deg C
I know because I have sensor and gauge.
850C = 1562 deg F. I submit this is, shall we say, a bit . . .toasty. Which simply serves to support Jeremy's observation.
I would think charge temps ex-compressor somewhere in the 140s C. Depending on the current IC efficiency, IATs 60-65 deg C.
Golosok wrote:EGT never went pass 850 deg C
Is the sensor before (in the manifold) or after (in the downpipe) the turbo?
Golosok
Post by Golosok »
The sensor is inside the manifold, almost in the middle, little bit closer to front.
850C is getting to be nearly too hot. What are your IATs?
