Page 36 of 57
Re: Vlad: The Zinno '87 535is (Euro Bumpers!)
Posted: Jul 01, 2015 2:38 PM
by leadphut
it's more of a rectangle. those operators were never good with geometry.
Posted: Jul 01, 2015 4:00 PM
by tig
Decision made: Full respray.
Ken's pulling trim now and we're gonna pull the windshield tomorrow early. I was waiting for the windshield in there to get broken before replacing it (it's pitted but OE) but this will force my hand. I have a brand new OE green-top windshield for it.
This also means I will put on my real shadowline trim vs the lame vinyl tape I've been living with.
Plan is to have it done Friday afternoon so it can sit all weekend. Then I'll have to get it to my auto glass place early next week.
Posted: Jul 01, 2015 4:36 PM
by davintosh
cek wrote:Decision made: Full respray.
Yay! :banana:
Posted: Jul 01, 2015 5:28 PM
That doesn't seem like sufficient time to do the bodywork, block it, let things settle and then spray paint and let it cure. Seems like you're rushing it.
Posted: Jul 01, 2015 6:42 PM
by bkbimmer
I hope you aren't getting it done before 5er. What christ said.
Posted: Jul 01, 2015 6:48 PM
by tig
Primer today. Block / sand tomorrow. Paint Friday. That's too quick?
Remember the current paint/bodywork is pretty much perfect.
Posted: Jul 01, 2015 7:03 PM
by OcCoupe
cek wrote:Primer today. Block / sand tomorrow. Paint Friday. That's too quick?
I keep wanting to respond to this; but I know that no matter what anyone says, you are going to do it your way. Best of luck.
Posted: Jul 01, 2015 7:05 PM
Well, I didn't consider that the bodywork was perfect. I have never owned a car that nice before. I'd just wipe it down a with a tack cloth and spray it but I'm sure Ken might spend an extra day on it.
Posted: Jul 01, 2015 7:14 PM
by tig
Really? You really don't think I value your, Brent, and Chris's input?
Posted: Jul 01, 2015 7:23 PM
by OcCoupe
Regardless of whether or not you value it, you tend to not follow it. There's no need to reengineer a process when so many people have proven the right and wrong way to do things. If you want to rush it then by all means rush it. There are things that need to take their course and you will not allow that to happen by rushing the job. In addition you need to research the paint. Not all single stages are created equal. If you paint over primer that is still out gassing then you can end up with all sorts of issues under the base coat. This goes the same with body filler. After all is said and done you want to slap the trim and windows on the car. I've seen paint twist when someone was trying to put the trim on a car that had 4 month old paint. Trying to rush this will only lead to inferior results. Oh and by the way, when is Ken going to do a color spray out for you?
Posted: Jul 01, 2015 7:27 PM
by OcCoupe
I should also ask how familiar Ken is with shooting modern single stage?
Posted: Jul 01, 2015 7:28 PM
by tig
Can you explain what you mean by color spray out?
Posted: Jul 01, 2015 7:33 PM
by OcCoupe
cek wrote:Can you explain what you mean by color spray out?
Two weeks prior to spraying color and clear on the coupe Marco sprayed out 2 color swatches based on the example that I gave him. I approved the color and also owned it at that point. Prior to paint we did a final run through the check list which included re-fitting lights and bumpers, also the scope of work that was to be done at paint including what color went where and what texture when where. He had 30 or so photographs to go by and I needed him to sign off on each so that I knew he understood the goal.
Posted: Jul 01, 2015 8:35 PM
by leadphut
Posted: Jul 01, 2015 8:40 PM
You are going to have to draw a line somewhere and there will always be someone that will ask why you didn't do X or Y.
Posted: Jul 01, 2015 10:47 PM
by bkbimmer
I feel bad for Ken, he is most likely going to have a lot more questions to answer now. :rofl:
Whatever you do, don't lay your stripes down crooked or you will have to delete this entire thread. :lol:
Posted: Jul 01, 2015 11:57 PM
by mitch5
I will add to what everyone has said, never rush bodywork. This isn't gas monkey where you have to paint a car by some auction deadline.
In my personal experience, where i have sprayed and prepped everything myself, most high build 2k primer i have come across takes 2 days to cure before you should sand, that's given the right conditions. I know the everlast fiber fill is a quick cure primer,but not many people use it. When it was cold here in az i blocked primer i thought was cured then it gassed out and made the base peel. Remember 90% of the final product is in the bodywork.
Posted: Jul 02, 2015 8:48 AM
by cddallara
Feck it. There's always this option.
:rofl:
Obviously I'm new to this level (any level, really) of things, but if the body is perfect, what is primer for? I was always under the impression it was to help paint adhere to bare metal and/or filler.
Not arguing, just honestly curious.
Posted: Jul 02, 2015 9:27 AM
by leadphut
mitch5 wrote:I will add to what everyone has said, never rush bodywork. This isn't gas monkey where you have to paint a car by some auction deadline.
5erWest is this month.
Posted: Jul 02, 2015 11:35 AM
by tig
cddallara wrote:Obviously I'm new to this level (any level, really) of things, but if the body is perfect, what is primer for? I was always under the impression it was to help paint adhere to bare metal and/or filler.
As I lay in bed last night thinking about this, I had the same question, Corey: "Why does he need to primer the whole car?"
I stopped by his place this morning to help remove the rest of the trim and the windshield. And I saw, you are right; there are only five spots where primer was required. Three dings on the roof, one on the rear pass door, and the area where the paint was thin on the left rear quarter, which he had already painted yesterday. He's just sanding out the paint everywhere else. So the little primer that's there will have plenty of time to set before tomorrow. It helps that the temps here are in the 90s.
We got all the trim off, the lock trim removed, the windshield out, etc... this morning.
You've inspired me though. I'm going to use this instead of satin black around the bottom of the car. Talk about a unique look!
Posted: Jul 02, 2015 2:12 PM
by Reyno1dsWr4p
Such a beautiful 535is. Would you think about selling your 540i M-sport? Haha my favorite car :) :laugh:
Posted: Jul 02, 2015 2:32 PM
by tig
Reyno1dsWr4p wrote:Such a beautiful 535is. Would you think about selling your 540i M-sport? Haha my favorite car :) :laugh:
Like the idiot I am, I sold my 540i M-Sport in 2006. http://kindel.com/bmw/540msport.html
Posted: Jul 02, 2015 3:22 PM
by offroadkarter
It got hit by a city bus? Ouch
Posted: Jul 02, 2015 4:35 PM
by cddallara
:up:
:rofl:
Posted: Jul 03, 2015 1:01 PM
by tig
I stopped by Ken's place today and spent several hours helping with sanding and masking. I decided to leave him alone to paint this time ;-).
Posted: Jul 03, 2015 2:55 PM
I can't believe you left the lock cylinders in the doors.
Posted: Jul 03, 2015 2:58 PM
by bkbimmer
I can't believe it's not butter.
Posted: Jul 03, 2015 3:01 PM
by tig
wkohler wrote:I can't believe you left the lock cylinders in the doors.
Pulled the plastic trim off of them (have new).
Posted: Jul 03, 2015 3:06 PM
Posted: Jul 03, 2015 3:10 PM
by bkbimmer
I still can't believe it's not butter!
I think it's cool you decided to go with satin red, you should have Ken add a flame to the lock cylinders, it could be the one detail that really sets it apart from the rest.
