T3 Adaptor For Stock 745i Manifold Interest?
Jeez, you'd be half way to a used TCD manifold after paying for this poorly designed adapter for a shitty manifold.
Golosok
Post by Golosok »
Good & Tight wrote:You can buy a tubular manifold for $850. and run any turbo and wastegate you want.
Why mess with ancient manifolds?
It's very nice manifold, no questions. But it's top mount, so I will need to change all piping to intercooler. Also oil lines, downpipe, wastegate. Almost everything. With adapter I can upgrde turbo and do just a small change to downpipe, all the rest staes the same, or almost the same. Totally different investment.
turboinduction
Post by turboinduction »
If you have your own opinions on the topic then that is fine. Do I destroy an idea of a tubular manifold or a different cast manifold, NO. I have an old Cartech manifold and a TCD manifold, the cartech is cracked and I am using the TCD. I do not have a problem with these manifolds they are great manifolds but some people are looking for a different option such as this adapter plate.
AS far as my shitty designed adapter plate. You are seeing a rough work up, that was the first plate that we had made. IT is in no way finished. If I had known I was going to be faced with so much criticism I wouldn't have even brought the idea here and I would have taken it elsewhere.
So, I am asking anyone with a negative opinion on my idea to please stay out of this thread. If you don't have something nice to say please do not say it at all.
HiNick
Post by HiNick »
I also made one like these a while back, here's how it is mounted up:
turboinduction
Did you get respectable power out of it?
Did you bead blast and ceramic coat that manifold, its quite a beauty.
HiNick
Post by HiNick »
turboinduction wrote:Did you get respectable power out of it?
As my other project has gotten most of my time recently, I haven't gotten this baby tested out yet I'm afraid.
On the pic here it's only cleaned and sand blasted, haven't gotten the paint on yet ;)
