Page 2 of 2
Posted: Oct 25, 2013 10:07 AM
by mooseheadm5
I wonder if you can use a B34 rocker shaft in a B35 head.
Posted: Oct 25, 2013 10:12 AM
by KillerPM
mooseheadm5 wrote:I wonder if you can use a B34 rocker shaft in a B35 head.
I dont see why not. Give it a try
Are the rockers interchangeable?
I am going to run a B34 head anyway (as per Todd's advice).
Posted: Oct 25, 2013 10:14 AM
by mooseheadm5
Wait, which B34 head has 1 piece rocker shafts? I'm looking at the catalog and all I see are two piece, and that's what I remember from the last B34 I did.
Posted: Oct 25, 2013 10:16 AM
by KillerPM
mooseheadm5 wrote:Wait, which B34 head has 1 piece rocker shafts? I'm looking at the catalog and all I see are two piece, and that's what I remember from the last B34 I did.
Oh crap! Your right.
<<<SNIPPED FOR WRONG INFORMATION>>>
Posted: Oct 25, 2013 10:19 AM
by KillerPM
KillerPM wrote:mooseheadm5 wrote:Wait, which B34 head has 1 piece rocker shafts? I'm looking at the catalog and all I see are two piece, and that's what I remember from the last B34 I did.
Its earlier M30s that have a one piece...
And scrap that one piece... I went back to 1973 and they are all two...
Hmmm... My information source was incorrect...
Posted: Oct 25, 2013 5:30 PM
by LynnBilodeau
All the big six engines from E3 through E32 and 34 use the same rockers and shafts. Four shafts. Each one is different, i.e. left front left rear, etc.
Rockers are same back to about 1966, and are same as 2002, 1600 etc.
Posted: Oct 27, 2013 8:48 PM
by Cjames570
Am I gathering from this that it's a non-issue on a B34? I haven't had the valve cover off of mine yet so I'm not sure of the differences between b34/35 heads.
Posted: Oct 28, 2013 8:23 AM
by FirstFives Dictator
Posted: Oct 28, 2013 7:04 PM
by LynnBilodeau
Cjames570 wrote:Am I gathering from this that it's a non-issue on a B34? I haven't had the valve cover off of mine yet so I'm not sure of the differences between b34/35 heads.
Same problem on any of the big six heads, M90, b34, b35 etc.
Posted: Nov 06, 2013 9:56 PM
by sideways7
i have looked into having custom head studs made for my m30 application in a stronger material than the standard arp. something equivalent to arp's L19 material. the cost is extreme for one set but almost drops in half for the second set and so on. would anyone be interested in a higher quality set for some more money than arps? this would obviously be for extreme builds. let me know if you are.
mark
Posted: Nov 07, 2013 1:36 AM
by Shadow
well how much are we talking?
will they have the correct shoulder and thickness?
The L19 for s54 is $400
Re: ARP Headstuds and the rocker shafts on an M30
Posted: Nov 17, 2015 10:34 PM
by Nosis
Bumping an old thread to ask for thoughts on another possible solution to this problem.
What if one were to wrap .008in (approximately .02mm) steel wire around the bottom 2-3 threads of the UPPER threaded portion of the ARP stud (lower enough to ensure non-interference with the nut) and below for another inch or so. The result would be a "thickening" of the surface of the ARP by almost exactly the desired .04mm.
By pre-bending the wire around a dowel just smaller than the 11.9mm ARP shaft, and careful placement, the wire would hug tightly to the ARP. The wire would look like a spring around the shaft.
To address the concern of the spring un-screwing itself from the bottom few threads and then falling down the shaft of the ARP, some length of the top of the wire could be straightened and crushed under the large washers beneath the top nuts.
The wire...
http://www.amazon.com/dp/B0018N4GF8/ref ... YE82GK02HX
Maybe worky? Thoughts?
Posted: Nov 18, 2015 12:50 PM
by T_C_D
Nosis wrote:Bumping an old thread to ask for thoughts on another possible solution to this problem.
It's not a problem.
Posted: Nov 18, 2015 5:38 PM
by Nosis
T_C_D wrote:Nosis wrote:Bumping an old thread to ask for thoughts on another possible solution to this problem.
It's not a problem.
Whew... that was easy!
