Page 2 of 2
Posted: Oct 11, 2011 6:28 PM
by Scottinva
How different are the b34 and b35 cams?
Posted: Oct 11, 2011 7:17 PM
by T_C_D
Good & Tight wrote: Gear change for sure then, I think you should try the 3.73.
How tall are your tires?
I have a 410 enroute. 26" tall tire. 7000rpm rev limit.
Scottinva wrote:How different are the b34 and b35 cams?
500rpm onset of fat tq.
Posted: Oct 11, 2011 7:45 PM
by marc79euro645
it should be violent with a 4.10
good luck
marc
Posted: Oct 11, 2011 9:56 PM
by T_C_D
Gear ratio comparison
293
mph/rpm
47/6800
82/6800
117/6200
410
mph/rpm
34/7000
58/6800
92/6800
117/6200
Posted: Oct 12, 2011 8:19 AM
by Mr Project
The thing I loved about running 4.10 gears in my M30-powered E34 Touring was that when you were commuting, it drove normally and got roughly the same fuel economy because you were pretty much always 1 gear higher than normal. And when you wanted to come out of the hole hard, BAM. Even my NA B35 moved that 3700 lb beast around in an entertaining way with those gears.
Of course the disadvantage was that I was gear-limited to a top speed of about 120 mph (didn't want to run it to 6k in 5th for fear of the rocker arms).
Posted: Oct 12, 2011 7:11 PM
by RDAvena
Mr Project wrote:The thing I loved about running 4.10 gears in my M30-powered E34 Touring was that when you were commuting, it drove normally and got roughly the same fuel economy because you were pretty much always 1 gear higher than normal. And when you wanted to come out of the hole hard, BAM. Even my NA B35 moved that 3700 lb beast around in an entertaining way with those gears.
Hmm, and here I am running a 3.23 in the touring with the M30. I should have left the 4.10 in there. :lol:
Ah well the 3.23 will be better with the turbo anyway.
Posted: Dec 28, 2011 1:50 AM
by lito
if using a getrag 260/6 or getrag 265,a 3.73 final drive is a good match for drag racing.2.93final drive is a mismatch for drag though nice for top speed run. :banana: :banana:
