Minerva: The S54 powered, better than new, E28
jc72
Re: Project Minerva: S54 powered E28 daily driver
Post by jc72 »
wkohler wrote:Probably not worth thousands of dollars in machinework for the test fit though.
https://www.ecstuning.com/b-h-and-r-par ... 795725~hr/
surely good enough for a test fit.
I guess that's more common than I expected. The offsets for the 16s (even 944) aren't super friendly with adapters.
You can make test-fit adapters out of plywood or MDF -- I've done exactly that. I wouldn't rest the car's weight on them, but if you have the springs out, you can jack the body up and down and turn the wheels to determine the fit across the range of suspension motion.
yomenendez
Post by yomenendez »
Other than water what did you use to clean the hood insulator...
yomenendez wrote:Other than water what did you use to clean the hood insulator...
Is this a question?
About this thread?
About what specifically?
yomenendez
My mistake.....
Was referring to Maytag thread where you cleaned the hood insulator.....
Just looking for direction...
Cleaning product used.....???
Process you followed.....???
The insulator is NLA...just trying not to do any damage...
yomenendez wrote:My mistake.....
Please ask there.
Please ask there.
Oh brother... :roll:
Jake's been busy.
I'll let the pics speak for themselves.
bkbimmer
Post by bkbimmer »
Bitchin
:wave:
cek wrote:Jake's been busy.
Noice.
BenGerman
Post by BenGerman »
Man that color is insane. Can't wait to see it in person.
Are you going with the Autolutions shifter on the 6 speed?
I remember Ron had something pretty fancy for those transmissions.
BenGerman wrote:Man that color is insane. Can't wait to see it in person.
Current plan is to use the stock E46 shifter.
Meh. I'll be putting a different cover on there. Not at all happy with the way the 'light media blast' worked out.
Tempted.
Somewhere the metal trim parts that go here have gone missing.
Yum. Like new.
Thanks Kohler.
SS SS.
I'm debating the look of this. We soda-blasted it. All that I've found look too scratched. Alternative is to fabricate something metal.
Expansion bung used to be on other side of rad. We moved it over here. Much better, but I think we can come up with a simpler hose connection.
750i MC
SS. Yes I'm going there.
Erect. E23 shocks.
When we're done, I'm gonna have a lot of plated parts for sail. Plate all the things. All the time. I say.
Hi Ben.
No confusion here. Still confused about Vlad's rears.
Bronze.
Sweet dreams. :D
BenGerman
Post by BenGerman »
We should rename this thread to: manual how to rebuild an E28 to better than new.
Stunning work Charlie. Thanks for taking all the pictures! I will need them at some point as well.
BenGerman wrote:We should rename this thread to: manual how to rebuild an E28 to better than new.
Good idea. Done. Sort-of.
Thanks Ben.
Re: Minerva: The S54 powered, better than new, daily driver
The Recaros are totally awesome! Love them.
Ordnator
Post by Ordnator »
Great thread with exemplary attention to detail which is very well documented. :up:
Are you able to rotate the expansion tank 180-degrees? This could give you a cleaner looking hose run.
Keep on keeping on.
Regards,
Mick
delvin
Post by delvin »
Ordnator wrote:Great thread with exemplary attention to detail which is very well documented. :up:
Keep on keeping on.
Regards,
Mick
But then the lettering would be upside down :(
Ordnator
Post by Ordnator »
Keep on keeping on.
Regards,
Mick
Not if you are standing at the front passenger wheel looking at the "BMW" engraved on an M20 / M30 rocker cover, it is the wright way up then ;)
linen grey ghost
Post by linen grey ghost »
I'd keep the plastic OEM nose beauty piece, maybe heat it with a heat gun and then lay some books (weight) on it to flatten out the 'humps'; the texturing you created from the soda blast look period to my eye.
LeiseyJr
Post by LeiseyJr »
Looking tits as usual!
I think for the expansion tank, find a welder and block off the current bung and relocate that one or another one where the circle is on this picture. If that's the expansion tanks final resting place.
Image31926153477_fd999c36a6_b by samleisey, on Flickr
Spen
Post by Spen »
Jeez Charlie, you are a huge gangster. What an effort!
BTW isn't 425 Motorsports in Bellevue off 140th a bit? I know Cory at the wheel repair shop, Sound Wheel Works. Known him for many years. I see nice stuff outside 425 and didn't know they did work for you. Not that you couldn't do it yourself =) As always, thanks for adding a lot to the E28 community. I am glad to have known you from the basic beginning of your foray into E28's. Certainly taken it a lot further than me on many many areas! Bravo amigo
Moar progress & pics. I have to say it is absolutely KILLING ME that I'm not doing this work. So far, all of the work meets my standards, and the team at 425motorsports has been great to work with, but I love doing all this kind of work...and I actually KNOW I could do it well. But, alas, other aspects of life mean I simply don't have the time and if I want this car done (which I do!) I have to continue using my checkbook-wrench.
That said, I guess this is part of learning the checkbook-wrenching skill...
Enjoy the pr0n:
Oh, what wheel to use? Never loved the look of the Mtech 1. Love the Mtech 2 (385mm) thats in Vlad. Maybe I'd like a 370mm more? Regardless I'm getting this MTech 1 restored to full glory as the baseline.
I have two sets of front belts. One old (currently on car) and one new style (here). I'm guessing receptacles for new style are easier to come by (don't have a good set yet). Thoughts?
Image2019-03-11 15.02.07 by Tig, on Flickr
Upper door trim are all in fine shape except driver's door. Sourcing...
Image2019-03-11 14.59.35 by Tig, on Flickr
Driver's inside door handle is broken. Also sourcing...
Image2019-03-11 14.59.06 by Tig, on Flickr
We couldn't remember where these go. Then I remembered. (front door jambs)
Image2019-03-11 14.58.00 by Tig, on Flickr
Ugh. Based on this, I'm going to go with my old-style, Sofica, heater box. The wiring harness we're using is old style and would need to be modified to support the new style anyway, so this is just simpler.
Image2019-02-23 12.09.13 by Tig, on Flickr
One of the most critical components. My son asked "what's the most expensive, non-power train OE part". This is the answer.
Image2019-03-02 10.03.51 by Tig, on Flickr
Little plastic covers that go here are missing. @bengerman got me a set in Sandy Eggo!
Image2019-03-02 10.04.31 by Tig, on Flickr
Image2019-03-02 10.04.37 by Tig, on Flickr
Just test fit. These are now off at upholsterer....
Image2019-03-02 10.04.48 by Tig, on Flickr
Image2019-03-02 10.07.32 by Tig, on Flickr
Image2019-03-02 10.04.51 by Tig, on Flickr
Euro lenses (new).
Image2019-03-02 10.05.37 by Tig, on Flickr
Image2019-03-02 10.07.42 by Tig, on Flickr
Image2019-03-02 10.05.58 by Tig, on Flickr
Image2019-03-02 10.06.01 by Tig, on Flickr
Based on conversations this weekend, I may switch from this 924 booster to a 528e, which I now know fits.
Image2019-03-02 10.06.05 by Tig, on Flickr
Intentionally going simple on brakes for now (E34 BBK that came with chassis) knowing that once the car is driving we'll want to Get The Balance Right (channeling Depeche Mode).
Image2019-03-02 10.06.15 by Tig, on Flickr
Image2019-03-02 10.06.36 by Tig, on Flickr
Image2019-03-02 10.06.40 by Tig, on Flickr
Image2019-03-02 10.06.51 by Tig, on Flickr
Image2019-03-02 10.07.00 by Tig, on Flickr
Image2019-03-02 10.07.11 by Tig, on Flickr
Image2019-03-02 10.07.18 by Tig, on Flickr
Image2019-03-02 10.07.24 by Tig, on Flickr
Image2019-03-02 10.07.28 by Tig, on Flickr
Image2019-03-02 10.08.11 by Tig, on Flickr
Image2019-03-02 10.08.13 by Tig, on Flickr
Image2019-03-02 10.08.19 by Tig, on Flickr
Image2019-03-02 10.08.45 by Tig, on Flickr
Image2019-03-02 10.08.59 by Tig, on Flickr
Image2019-03-02 10.09.03 by Tig, on Flickr
So far the only thing that really pisses me off about this build. I wanted antenna delete.
Image2019-03-02 10.09.11 by Tig, on Flickr
Image2019-03-02 10.09.29 by Tig, on Flickr
Image2019-03-02 10.09.32 by Tig, on Flickr
Image2019-03-02 10.09.51 by Tig, on Flickr
Image2019-03-02 10.09.57 by Tig, on Flickr
Image2019-03-02 10.10.20 by Tig, on Flickr
I had to scramble to find a rear seat. Spen as awesome in helping, delivering directly to shop. The base is beige. At upholsterer...
Image2019-03-02 10.11.01 by Tig, on Flickr
Image2019-03-02 11.25.01 by Tig, on Flickr
Image2019-03-02 10.12.52 by Tig, on Flickr
Image2019-03-02 10.52.00 by Tig, on Flickr
Image2019-03-11 14.44.28 by Tig, on Flickr
Image2019-03-11 14.44.41 by Tig, on Flickr
Image2019-03-11 14.44.52 by Tig, on Flickr
Image2019-03-11 14.44.55 by Tig, on Flickr
Image2019-03-11 14.45.01 by Tig, on Flickr
Image2019-03-11 14.45.15 by Tig, on Flickr
Image2019-03-11 14.45.34 by Tig, on Flickr
Image2019-03-11 14.46.08 by Tig, on Flickr
Image2019-03-11 14.46.14 by Tig, on Flickr
Image2019-03-11 14.48.45 by Tig, on Flickr
Image2019-03-11 14.48.36 by Tig, on Flickr
Image2019-03-11 14.48.13 by Tig, on Flickr
Nick1984
Post by Nick1984 »
Respect! :shock:
Tiit
Post by Tiit »
Thanks for sharing. Looks great.
BenGerman
Post by BenGerman »
Rolled fenders?
BenGerman wrote:Rolled fenders?
Yep. Whew. Thanks for asking.
We didn't get a chance to catch up this weekend, and I know this is a silly question, but will this be unveiled at 5erWest in July?
