A big azz A>W heat exchanger!
:shock: Holy crap! Any guess to how well that works for that size motor or what IAT it sees under sustanied boost?
altus22
Post by altus22 »
Unless there's a massive pump in the system, I expect there to be problems with pressure drop across that heat exchanger, which will cause everything else to perform poorly. I say this because it looks to be a 2 pass. For a v8 putting out 1+ bar, I expect that you'd want a heat exchanger about twice that size to keep your coolant around ambient and your IATs as low as possible. If you've got the space, heat exchanger area is cheap.
Post by Coldswede »
Naw, I think that is the power steering cooler. ;)
