What is everybody doing with the fuel line that goes to the charcoal canister then to the intake manifold.
I was thinking putting a 1 way check valve in the line and route it to intake manifold so it's sucking vapors pretty much all the time.
Can MS control an evap purge solenoid easily? MS2
Evap and MS
Re: Evap and MS
Yours is wired to control it; I can help you with the settings.jim325 wrote:What is everybody doing with the fuel line that goes to the charcoal canister then to the intake manifold.
Or you can use that output for boost control.
