I was wondering if someone could post up there cold start wizard table for me. I cant seem to get my cold start right and still have to kinda hold the gas pedal for a sec. I have a idle bump valve but a good table would help me out a bunch. thanks
Batesy,
I don't know if these will work for you.
on warm up enrichment from top to bottom
150,150,150,150,150,118,115,110,100
prime pulse 7.0
@-40=6.0
@160=6.0
flood clear= 70.0
additive%=55
# of cycles=950
good luck
marc
marc79euro645 wrote:Batesy,
prime pulse 7.0
@-40=6.0
@160=6.0
flood clear= 70.0
additive%=55
# of cycles=950
good luck
marc
I'd disable that priming pulse. Every time you cycle the ignition you're getting 7ms of fuel injected. If you get the cranking pulse widths dialed in you don't need anything else to get it to light up. Once its running ASE and WUE kick in.
WUE should be more or less linear with more fuel required for colder running. I'm not sure if I understand the data you posted correctly but it looks like it takes pretty big steps down. It works best when ramped down gradually, like the other enrichments.
prime pulse 7.0
@-40=6.0
@160=6.0
flood clear= 70.0
additive%=55
# of cycles=950
good luck
marc
I cant to figure out today where those number go compared to mine. Im running tunerstudio latest.thanks for the help. btw thats all my cranking tables.
Mine seems to like the prime pulse.
I also have my timing starts at 10* @ 100kpa,
peak up to 25*@ 70 kpa
then drops to 20* for idle.
This starts fast & gives a nice little rev,before it settles to idle.
marc
Batesy,
I'm using megatune,v2.687 firmware, so it looks different than tunerstudio w later firmware.
the first list of #'s represent ase %(lower right on your screen.
I live in Florida so I haven't tuned below 40F.
prime pulse is on the left
marc
WUE percentages can probably be used but other settings may or may not apply. The problem is that other settings affect warm up and cold start running so without implementing everything it may not work very well at all.
Scottinva wrote:You guys can't compare warmup enrichment numbers unless the version you are using is the same. Why in the world don't you have ASE turned on?
I turn off ase due to a problem I was having, never turned it back on.
What is the different between ASE and Warm up wizard on tunerstudio, seems it doing the same thing anyway.
Watch your vr pulse on the left megasquirt led. If your car is cold or battery low,or cables dirty, low cranking rpm for any reason,will cause you not to get vr pulse. When my car is cold I might have to crank for a couple seconds to start getting pulse.
Looks like you got the ase %s right. but I'm sure you'll need to tune them for your conditions. I would datalog start up.
marc
