Switched 12v locate - multiple conductors
So I am wiring up my LC-1,DB gauge for lc1, knocksense knock detector, and MSD 6a units and I am pulling all the grounds to a distribution block to run to the engine ground and I need 12v switched for all of these- I would like to pull one heavier gauge wire from a good source and distribute from one location ( near passengers strut mount- due to shorter O2 lead for lc1). I have all power cables pulled to this point and it would be awfully handy to connect all to distribution block wired from one source- wherever it needs to come from. Obviously I'm not an electrition but I don't want to overload the source. I know the fuel relay is a good source but it sure seems like this could cause a meltdown of sorts. I'm trying to keep random wire tapping sources down-
Thoughts?
Anything requiring direct battery connectivity (6a) is getting that from source.
Thanks and I have been dreading this portion for a while!
9 [/list]
Thoughts?
9 [/list]
- Beamter
I did mine with 2 relays, one dedicated for fuel pumps,one that feeds a terminal strip, mine wasn't bussed so I had to make short jumpers to feed the posts, for injectors,sensors, & ms.
speaking of relays I recently checked the voltage of my lame a/c blower fan, only 8.5 volts. I installed a new feed & relay.
I was very happy at how much better the fan blows at 12.5 volts.Also buy a 3rd relay & put it in your glove box.
good luck
marc
good luck
marc
- Beamter
- Beamter
- Beamter
- Beamter
