demetk
Posts: 8431 Joined: Aug 09, 2007 8:58 AM
Post
by demetk » May 24, 2012 12:02 PM
Couldn't find an answer using search, so obviously I still suck at it.
I just received the o-ring took from Moosehead and have a question on what diameter to set the cutter at. Do you just take the bore to bore distance and third it or take the gasket ring diameter and halve it or is there a simpler process?
TIA
Lurker27
Posts: 207 Joined: Feb 10, 2009 8:21 PM
Post
by Lurker27 » May 24, 2012 1:54 PM
I set mine to the center of the metal part of the stock head gasket I was using (Elring Klinger IIRC)
GI jonas
Posts: 371 Joined: Feb 15, 2012 10:06 AM
Post
by GI jonas » May 24, 2012 3:48 PM
Lurker27 wrote: I set mine to the center of the metal part of the stock head gasket I was using (Elring Klinger IIRC)
This I believe correct.Or possibly a bit father to the outside of center.
M. Holtmeier
Posts: 3025 Joined: Mar 11, 2007 3:06 AM
Post
by M. Holtmeier » May 24, 2012 4:04 PM
I set mine to the center of the metal fire ring.
demetk
Post
by demetk » May 24, 2012 4:09 PM
I think that will work just fine. The gasket ring is .205" so I used .205/2 + .005 = .108" from edge of bore. I think the pattern looks great.
Thanks for the replies.
