ar design: E28 LSx Turbo Build
ar design
Post by ar design »
Just picked up an E28. I've been itching to do an LSx turbo build ever since I sold my twin turbo C6 a few years back.
So.... Here goes! Build will take place over the next 2-4 months, depending on how over budget I go ;)
11-8-12
Engine removed, started working on stripping interior, insulation, and absolutely everything that is not essential. We are going to try to have this thing down to about 2500lbs.
BMW insulation is HEAVY! Image
Shadow
Post by Shadow »
Is that the trunk tar?
On my e30 it was about 48lbs.
ar design
Post by ar design »
Yessir.
You know I support this build! :banana: Details? HP goal? Tranny? Purpose of car?
ar design
Post by ar design »
T_C_D wrote:You know I support this build! :banana: Details? HP goal? Tranny? Purpose of car?
No real set goal. Street hoonage / drifting? 4 speed T101.
Decimate all.
Jelmer538i
Post by Jelmer538i »
Nice! Another one!
ar design
Post by ar design »
Saturday update!
Got a bunch more insulation removed. Heat gun, scraper, and a hammer. What a pain!
Tex Racing 101 (G-Force GF-4A) 4 speed dog box purchased!
OEM LS7 Camshaft Purchased.....
ar design
Post by ar design »
Got the 5.3 out of a 2003 Silverado. And cleaning up engine bay. Getting rid of the LS7 cam, probably going to go with something a bit more aggressive.
ar design
Post by ar design »
Update..... Got the motor apart. Regapping the top rings to .026. They are .015 currently. Bottom rings are fine, no need to re-gap. Broke one of the OEM rings, had to get a set of new ones, $49. OEM pistons were FILTHY. So much carbon. And the oil control rings were totally gummed up / frozen. Once finished re-gapping rings, installed some ARP2000 rod bolts (pre-01 motors have weak rod bolts), got a Weldon 2035 pump and a Weldon 2040 FPR off eBay. And my Tex Racing T101 showed up today! Turns out the seller DID include the shift linkage ($$$) and all I need is a shift rod. W00!
Right now, shopping for a NASCAR triple plate clutch on eBay.
ar design
Post by ar design »
Billet Alternator flip kit from LS1Brackets.com
Triple disk Quartermaster 7.25" clutch, NASCAR takeoff, $180 FTW!
NGK Spark Plugs $2/ea
Lakewood Bellhousing for transmission... SFI Certified
Heads back from machine shop. Springs/retainers installed, decked, cleaned up, installed height checked, etc. $226.
Installing eBay head studs. LOL
Welded 10AN return fittings to the GTO pan
Dem ports iz HUGE!
Headgaskets installed
And I purchased a sweet Southbend manual lathe. Its a beast!
itsbrokeagain
Post by itsbrokeagain »
glad to see you on here Andrew :)
ar design
Post by ar design »
Yeahhhh buddy!
ar design
Post by ar design »
More progress!!!!!!!!!!
Engine and transmission are mated......
Getting ready to go in.....
Come to papa!
Almost there.....
Transmission ended up needing more room. So....we decided to give it more room!
And its in!! Engine mounts and transmission mounts are done, pics of those when I get them out of car. Engine mounts are available for sale.
GTO oil pan fits perfectly, no mods!
Taking undercoating off to weld new tranny crossmember in....
Fabricating a new tunnel, and pushing the firewall back to make room for the exhaust.... ;)
Flanges for tunnel to attach to via DZUS fasteners.
Intercooler core... its HUGE! 4.5" thick!
Random.
Jelmer538i
Nice nice nice! These are the projects to look at!
