My M30B35 Turbo build
Yip, you have it right! Could not find enough space for the turbo down pipe at the rear of the engine bay as steering collumn takes up most of the space!! Hence I had to turn the turbo around and install this 100mm pipe to get cold air to the turbo! Please note that this is an installation in progress and many things can still change?? I will post another picture of the current set up!Black Steel wrote:Nice. I have a RHD 28 too so no how hard it must have been to figure out where the exhaust down-pipe was going to go.
The problem I have is the ABS block is in the way.
Well done. Would like to see some more pictures please
abs pump can always be moved, on my e30 i needed room for the charge cooler
stuck the pump in the empty battery tray
Your pictures do not work.winfred wrote:abs pump can always be moved, on my e30 i needed room for the charge cooler
Great picturesE12 535i Turbo wrote:I am in the chemical industry and by no means good at any mechanical work! I however wanted to do everything myself but almost gave up when it came to the turbo header! I however conquered!!
Welding the header in place.
Complete with the welding
Ceramic coated inside and outside.
Thanks a lot!!Black Steel wrote:Great picturesE12 535i Turbo wrote:I am in the chemical industry and by no means good at any mechanical work! I however wanted to do everything myself but almost gave up when it came to the turbo header! I however conquered!!
