Anyone successfully ran an IAT in their intake manifold?
I've read mixed reviews on this topic. Due to my new configuration, the intake would be convenient (but not essential).
Scottinva
Post by Scottinva »
I've seen heatsoak issues, giving false readings. I suggest placement in a charge piping. I have seen the plastic bodied ones that seal with a rubber grommet work quite well.
marc79euro645
Post by marc79euro645 »
I mounted mine opposite the throttle, but it has required 2 -3 trys to restart on hot days. I 'm planning on moving mine down near the i/c.
marc
winfred
Post by winfred »
elbow at TB
Good & Tight
Post by Good & Tight »
Mine has been in the intake opposite the TB, never had issues with hot starts. Once you have air flowing over it, it's fine. IMO it should be in the intake, it's more accurate of reading the actual temp entering the engine.
Good & Tight wrote:Mine has been in the intake opposite the TB, never had issues with hot starts. Once you have air flowing over it, it's fine. IMO it should be in the intake, it's more accurate of reading the actual temp entering the engine.
Got a picture?
