Smoke at idle
Patrick McHugh
Smoke at idle
Post by Patrick McHugh »
On the way down to vintage we pulled into a gas station and my TCD 535 turbo started pouring oil smoke from the tailpipe. I shut it off and got gas and started it back up, same thing. We drove 4+ hours down to the show without issue. The car behind me reported a faint oil smell at times but no smoke visible.
It acted fine at the show, multiple starts and stops, and then did it again on the way home. It has been doing intermittently ever since.
I haven't ruled out valve guide seals, but there's no smoke on high RPM deceleration.
This engine has always has and still runs strong, quiet and smooth, but I did struggle with some detonation issues due to high MAT and timing issues a few months back, it could be getting past the rings, a differential compression test and spark plug will reveal that.
I suppose my big question is how does one check turbo seals for leaks? That would be great if that's all it was. It would also be an excuse to put a more modern turbo in it.... :)
Is the cold side oily?
Patrick McHugh
It's always been a little bit oily, i'll pull the intercooler when I check the plugs, i'll let you know if it's crazy oily.
Patrick McHugh wrote:It's always been a little bit oily, i'll pull the intercooler when I check the plugs, i'll let you know if it's crazy oily.
Sounds like the turbo.
Hot side seal can fail too. Thats what happened on my old journal bearing unit. Smoked like hell on spoolup, only slight smoke otherwise. Barely noticeable.
Hot side seal failure is likely if the plugs show no sign of oil burning.
