Prepping to setup/configure Electronic Boost Control
I'm considering making the move to EBC & am about pull the trigger in ordering the components to build the circuitry. Currently I'm running MS2 that I build myself. I should have enough room on the proto area to build the ebc circuit, but I'm wondering how to setup the heat sink for the FET that is required. Can I just cut a small piece of aluminum & bolt it onto the transistor?
I guess this is also a pic request for how you configured your circuit.
Shadow
Post by Shadow »
Mine is just on a strip of aluminum all the other fets are on.
The wiring is ultra easy and so is the tuning ;)
Shadow wrote:Mine is just on a strip of aluminum all the other fets are on.
Convenient setup. You mounted it on a Glens Garage board? I could slap it there or stuff it on the proto area of MS & tie into an open lead on my db37 (if there is one).
