Intake manifolds
Intake manifolds
Is anyone making intake manifolds for M30s? I need something with a tb that faces the LF headlight.
Re: Intake manifolds
are you opposed to flipping the oem throttle body to the other side of the factory mani?
Yes.
I remembered this thread:
http://www.mye28.com/viewtopic.php?t=84617
I don't think we ever saw finished photos or exactly where/how the air got into it.
I also think there was someone who posted a solidworks drawing of an intake which had a similar design to that. Can't seem to find that at the moment.
I bookmarked this one to read further a few years back (don't think I did) after it was brought up in a thread - a quick skim had some good info on designing the plenum for somewhat even air distribution into the runners. I figure that since it's based on a 6-cylinder motor, perhaps maybe it could be the slightest bit helpful.
http://forums.hybridz.org/topic/61549-t ... ke-plenum/
I remember a guy's manifold burst apart after a backfire or something - which was bad. I didn't search for his thread but it was sometime in 2009 or 2010, I think.
Beyond that, I've got nothing. I'm not an engineer and I've never stayed in a Holiday Inn Express. I know the flipped manifold thing is popular but I cannot imagine it's optimal. Very interested to see what you come up with.
do you have a budget and overall power level in mind? i can build one for you.
Sideways, going to PM you...
Like Chris posted above, that's exactly what I'm looking into. (Thanks for the info, btw, Chris) Flipping the throttle body on a stock manifold isn't an option as the build currently outflows it.
Well don't leave us hanging. What turbo are you using?
marc
marc
- Beamter
Nebraska beef & cowtipping is enroute to new levels! Let's do this.
You say you're manifold is restricting power?
Once I get a tube exh manifold and custom intake on, I'll know for sure. It's going to be kind of a clean slate turbo system- except I'm reusing my turbo. If I still have problems at higher boost levels, then I'll know it's the turbo. I haven't been able to take full advantage of Pual Burke's cam and all the head work that was done since building this engine 2 years ago. The first year was fuel supply issues and a blown HG. The second year was low boost driving- just trying to keep it together. This year is high boost but no more power. Current turbo is TCD's 60 trim Comp Turbo upgraded with a 67mm wheel and a .83 turbine housing.
