M21 Engine Rebuild
z122643
M21 Engine Rebuild
Post by z122643 »
So, a number of years ago I helped a friend buy his 524td. It had originally been a barn find in Fresno. At the time he bought it had 180,000 on the clock, but the odometer stopped four years earlier. It was leaking a lot of oil and fuel. Fast forward to now and the oil leaking out is exceeding the input by him. Time for an engine rebuild!
I will be posting pictures as we work, there are a lot of mystery sensors. So far everyone and their kid sister has told us that we are completely insane!
"Custom" jack stands
"I ask you, who the F*&K loops the engine wiring harness through the intake flanges?!"
At TDC
noddaduma
Re: M21 Engine Rebuild
Post by noddaduma »
Nice start! Keep us posted.
z122643
Post by z122643 »
z122643
Post by z122643 »
Well these should be fun for someone.
Kopek130
Post by Kopek130 »
Dang so many photobucket accounts have been slammed.
I've managed to snag saving the page to pdf before it happened. Here it is here.
https://1drv.ms/b/s!Ar5iUNh_SbR27mKpw-4D8A70ep09
z122643
Post by z122643 »
$400 to restore all my photos. Ransom-ware! FUCK THAT!
Kopek130
Post by Kopek130 »
How's the rebuilding going? I'd love to do that to mine. Also post what brands of bearings you're buying!
z122643
Post by z122643 »
Currently in the cleaning stage. I don't know if people want to see that ;v). As for bearings I will be using King bearings.
z122643
Post by z122643 »
...and we're back. We had some work/life issues come up but we will start up the old engine project again.
Starting with a question. Anyone know how to remove the block heater?
gadget73
Post by gadget73 »
Lots of work, thanks for the pics.
Took a quick look in the manuals I have and I didn't see how the heater comes out. I want to say mine looks different than yours anyway. Wild guess, I'd expect an expansion plug situation, either the thing unscrews some to release or it has a bolt through the center to expand a rubber plug.
z122643
Post by z122643 »
A lot of digging later
gadget73
Post by gadget73 »
hm, seems Ford neglected to put that bit in their manuals.
z122643
Post by z122643 »
Sorry for the absence. We have been having trouble sourcing some parts. We had the stock pistons and rods on order with BMW but they back ordered them with no ETA... so I'll just have to make them myself.
Heat block finally out, the manually lied. It took some generous swings of a dead blow hammer to remove.
Time for a bath
z122643
Post by z122643 »
So update, we are back on track after some issues. First we sourced original Mahle pistons out of Ukraine (don't ask), I replaced my wife with a dog, and I'm currently designing new connecting rods. Shouldn't be long now.
In the mean time we have baked and shot peened the block. He choose the color not me, though it might change based on his expression :laugh:
gadget73
Post by gadget73 »
Please tell me that isn't Chevy Orange.
Looks nice though. Honestly less bland than the black paint job mine sports. Its black or its just a sheen of old diesel oil, not completely sure.
Why are you designing new con rods?
z122643
Post by z122643 »
gadget73 wrote:Please tell me that isn't Chevy Orange.
It is Chevy Orange :( . After inspecting the rods we found the bore parallelism out, the big end out of round, and PE bore oversized. It make sense to get new ones, and we the facilities to make new/better ones.
gadget73
Post by gadget73 »
good deal. What happened to that poor engine to make it so messed up, just lots of miles or was it abused?
mildly scared whats going on inside mine. Odometer says 195k. The car does not look like a nearly 200k mile car but I have nothing else to go by. It doesn't need oil between changes, so I suppose thats a good sign.
z122643
Post by z122643 »
Update:
did a dye check on the head and it's cracked. It was cheaper to get a new head then repair the cracked head. Getting closer to assembly.
We want to send out the injection pump for a rebuild. Any suggestions where to send it?
kingoftarmace2004
Post by kingoftarmace2004 »
where did you find the cracks? just outta curiosity? Thanks! -Paul
z122643
Post by z122643 »
All the cracks were found between the intake and exhaust valve seats. Using a sonic thickness gauge we estimate they were up to .050" deep. Not great but would have still run for a long while.
z122643
Post by z122643 »
Progress,
Captain obvious here, COVID sucks! Many delays later we were able to assemble the head. Sourced the new head from ECS, and intake/exhaust valves and rocker arms from Schmiedmann. The camshaft and all other seals/gaskets from BMW. As soon as equipment is available I will hone and deck the block. I also have to get the connecting rods made (because I can)
gadget73
Post by gadget73 »
Does the oil feed tube have pinholes in it so it works as a sprayer or is it just a tube? I honestly didn't check that out on mine when I had the cover off. Just wondering how the cam lobes are meant to lube on these.
kingoftarmace2004
the cam "sprayer" tube. has holes every cam lobe. it kinda just puts a stream over the lobe as it spins to give it some lubrication. I know you did not ask me, but hey. -Paul
Subscribed! Love the orange.
gadget73
Post by gadget73 »
kingoftarmace2004 wrote: Sep 21, 2020 10:40 AM the cam "sprayer" tube. has holes every cam lobe. it kinda just puts a stream over the lobe as it spins to give it some lubrication. I know you did not ask me, but hey. -Paul
Answers is answers, I'm not picky who they come from. Thanks. Next time I happen to have the cover off mine I'll make sure the holes are clear.
z122643
Post by z122643 »
gadget73 wrote: Sep 21, 2020 11:54 AM
Interesting side note, during the disassembly we noticed that two of the cam lobes were badly scored. Turns out the holes in the "sprinkler" for those lobes were blocked. If you are going to clean the holes use vacuum, do not push the blockage back into the tube, it will just flow to the next hole and block it. You can check if you have a blockage fairly easily by running the engine with the cover off and observing oil flow.
gadget73
Post by gadget73 »
Thats kind of what I was wondering. I may just pull that tube off and give it a good flush next time things are apart to prevent possible future issues. My cam is in really nice shape and I'd like to keep it that way. I have no idea what the maintenance history is on this thing but everything I've seen so far makes me think it was pretty good.
z122643
Post by z122643 »
So as I began designing the connecting rod I found something interesting (not unexpected, just interesting). The amount of edge loading at the 6 o'clock position on the pin end was excessive. Just as a sanity check I took a look at the original rod and sure enough excessive edge loading can be observed. There are a couple of design changes I will have to make, ideally I would change the pistons as well but I already have new OEM ones :roll:
kingoftarmace2004
by the way, what is it that you do for a living that you have access to such very cool tools!? Thanks! -Paul
kingoftarmace2004
also that is the "load side" of the pin. i know round objects should have really no load side but. in theory, just mybe it was engineered or intended to accept all that brute force that the diesel produces. just my two cents -Paul
