BOV options
Posted: May 08, 2018 9:52 AM
by 5timesturbo
Recently I was told that i can not run a HKS BOV on my turbo 535i with stock engine management. I was told my only option is a BOV that reroutes the air back in front of the mass air flow sensor. Is this correct? Ifso does this mean I wastedmy money on a hks ssqv bov?
Re: BOV options
Posted: May 08, 2018 10:01 AM
by demetk
Pic?
Re: BOV options
Posted: May 08, 2018 12:40 PM
by tschultz
If you blow off, the engine won't read the air being discharged and you will instead get a rich condition as the engine expects more air. When I had Motronic, I used a divertor valve from a VW to plumb back in after the AFM but before the turbo...
Re: BOV options
Posted: May 09, 2018 1:22 AM
by George
What Tom said is correct. Depending on the boost level and fueling the engine might stumble with the overly rich condition. A diverter valve will eliminate this issue.
Re: BOV options
Posted: May 16, 2018 2:06 AM
by Shadow
i don't know anything about your setup but just by the comments you have the AFM right before the turbo?
There is a DV adapter for that hks so you can still use it that way.
https://www.vividracing.com/synapse-eng ... 05272.html
Are you not running a valve now?
