Problem: My car makes a clunking noise when I put it in reverse.
Solution: Replace broken differential mount.
Difficulty: Straightforward, one big bolt holding differential to mount, four M8 bolts holding mount to unibody. Consider using the M535i part as a replacement, it is beefier.
Car makes a clunking noise in reverse
