looking for e23 parts
i need parts for an e23 if anyone can help let me know
- Beamter
Re: looking for e23 parts
Thanks for posting this in the right section!sergboost wrote:i need parts for an e23 if anyone can help let me know
You might get lucky with a few leads on this board since gear heads travel in packs. One other place you might check is here: http://bmwturbos.scottiesharpe.com/
Good luck!
grsmonkey, I'll give you a buzz tomm!
well my car is an 83' 728i euro. i need a new header panel,both front fenders,a hood, dash ,door handels ext. and ent., etc. i checked the car over and it look to have taken a small hit in the front ( header panel ,hood,and fenders are covered in bondo) but all in all the rest of the car is straight,
i got some cancer on the doors but thats about it, the typical interior cracking and faded................... well guys thanksfor taking the time
e23
Hate to say this, but you will spend much, much, much more than the e23 will ever come close to being worth on the market.
I have a rust free '86 735i that I've had since it had only 50K. Now, at 250K it needs a transmission and while I could do the work myself, with the typical HVAC troubles, I would be spending $1000 and then have a $700 car. I have both an auto and a 5-speed that could go in it and I do do dumb things sometimes... just not that dumb.
Otherwise I'll work something out with you for the parts you need. You will have to come and remove them & haul them away. Our grilles are a bit different...
But honestly, unless there is a hugh emotional tie, you can get a much better starting point. Junkyards are full of e23s with nothing much wrong but HVAC problems.
my car came with a 5-speed i actualy want to do a different type of job to the car, i want to fix the body , in terms of engine i was thinking of transplanting a 745i turbo motor, running a haltech ecu and the hvac would be extra. i want to build a street car with a race car flare. i know it will be hard due to the cars weight but i love the shark, and this is the first one that i come across in this good shape down here.
