This is more or less complete, you obviously need head gasket kit, timing belt kit, head bolt set, oxygen sensor, ignition plugs, ignition wires, waterpump, new motor mounts and to put in a catalyst after the downpipe, resonator back also included but not shown. Cat NOT included.
Optional higher amperage alternator with cold air intake 110 extra, rebuilt higher amperage alternaor with cold air intake 200 extra. Higher amp alternator comes with mounting hardware and bracket. Delivery available in CA for gas plus time depending on how far you are.
1500 for everything
528e super eta wiring harness
528e motor mount arms
325i 272 duration camshaft with 1.1mm+ lift
528e super eta downpipe
528e super eta resonator to muffler
325i pre air box boot
325i air box
325i air flow meter
325i throttle postiion switch
325i evap sensor
325i evap sensor boot
325i idle control valve
325i idle control valve rubber retainer
325i idle control valve rubber retainer bracket
325i throttle body elbow
325i throttle body elbow boot
325i throttle body
325i intake bellows
325i brake booster vacuum line and check valve
325i intake manifold
325i throttle cable bracket
325e intake manifold dual vacuum port
325i white top fuel injectors
325i fuel injector clips
325i fuel rail
325i valve cover
325i valve cover/timing cover bracket
325i rotor retainer
325i rotor
325i cap
325i cap and rotor dust cover
325i cam sprocket
325i exhaust manifolds
325i alternator
325i timing cover
325i lower timing cover
325i alternator idler
325i AC bracket
325i alternator bracket
325i power steering brackets
325i crankcase tube
325i reference sensor
325i reference sensor bracket
325i thermostat sensors
325i ignition coil
325i BOSCH 525 ECU
325i DINAN chip for 525 ECU
325i harmonic balancer
325i water pump pulley
325i timing belt tensioner spring
325i timing belt tensioner spring retainer
325i AC/Power steering/Alternator pulley
325i rebuilt gear reduction starter
Euro 323i 12.5 pound flywheel
325i new never used throwout bearing
325i friction disc with 3000 miles
325i pressure plate with 3000 miles
325i complete cylinder head with 119,282 miles
528e super eta short block wth 119,282 miles
rebuilt b35 starter is 150 shipped
near complete 2.7i m20 also rebuilt small b35 starter
Pretty!!!!!
Hope you sell it! Mine will be availabe soon too! I'll let it go CHEAP!
