Board Colors / Personalization
William
Post by William »
Right now we have the default board appearance called "Plain Jane" , which is simple and mostly white.
You can also select "Orange" which is a bit more colorful, or "blue" which is dark blue.
To do this go to User Cp / Board Options / Skins.
The board will remember your selection and appear the same way the next time you visit.
Of course you can change your preferences at any time.
Craig -535i- Seattle
Post by Craig -535i- Seattle »
Both are nice, but the "Orange" isn't really all that orange. :)
Bryan in NC
Post by Bryan in NC »
William - I've selected plain jane, but any way to see just text - no avatars or sig pics? I'd like to avoid having to load all the additional junk and don't want to draw attention to the fact that I'm cruising to board at work.
Tim in N FL
Post by Tim in N FL »
Hi William,
Is there anyway for the menu-driven HTML tags to be used more easily? For example, if I highlight a section of text and click the "italics" button, in vBulletin (and whatever is used on www.rennlist.com ) the tags drop into the appropriate location. With the CuteCast interface the tags are dropped in at the bottom of the message being typed. Please advise....and thank you! :?
Tim
