FS: MANY Parts - Parting Out 87 535is 5spd
mr_biased
Post by mr_biased »
Hi Everyone,
A slew of parts are available and I am clearing it all out. Will update list as best I can. Please feel free to ask for parts not listed, most likely it's sold but always worth a try. Due to the amount of parts, pictures can be sent for the parts requested. Car is 87 535is, Lachsssilber Metallic (203).
The car has very little or no rust so it will also be cut up for various body parts in the hopes of saving others. This will be completed in the next few weeks before it's sent to the recyclers. Please let me know if there are specific panels you are looking for.
Please make a reasonable offer including shipping and include ZIP code. The worse I can say is no or ignore the lowball offer... ;)
Parts are located in Orange County, California. Pick up is highly encouraged.
PARTS ALREADY SOLD:
BODY EXTERIOR: Front+rear bumpers+front valance, Both fender, complete Driver's door, [Both] Side view mirrors, Hood, Sport wing, Front kidney grills, complete Rear passenger door
INTERIOR: Steering wheel, Interior carpets, Front passenger+drivers sport, Manual pedal box, Trunk carpets, Rear window regulators, All door seals
SUSPENSION + BRAKES: Rear and front struts, All calipers and rotors
ENGINE + DRIVETRAIN: LSD, Complete exhaust
SPECIFIC PARTS AVAILABLE AND READY TO SHIP:
QTY / Description / Part Number / Comments
2 switch combination adjustable seats 61311375153 - faded symbols
1 safety switch electric window lifter 61311385796 - blank black square switch
5 window switch illuminated 61311381205
1 switch illuminated (lift up slide back sunroof) 61311377905
1 mirror switch with change-over switch 61311363459
1 ashtray front 51161911696
2 rubber pad for brake / clutch 35211113906
2 [interior b pillar] plastic cover [seat belts] 51431873249 - broken in the middle
2 interior door handle trim [No PN] - black square interior door handle surround trim
3 [grab] handle 51161888099
2 cover loudspeaker SOLD
1 interior dome light
1 leveling switch radiator [coolant tank] 61311375715 - new
1 air channel right 64111368722 - to the left side behind center console of passenger side
1 [seat belt bolt] covering cap 72111904665
1 complete manual 535is instrument cluster w/ recently replaced odo gears
1 switch air conditioning 61311367620
1 fader controler with flat-type connector 65121375982
2 door base handle left 51211904493 - for the inside of the door, not interior door handle
2 handle (e28) 51211919083
1 handle (e30) 51211923996
1 safety belt front right 72111870482
1 safety belt front left 72111870481
1 [sport seat lower plastic] cover 52101919098
2 rear headrests w/brackets 52201929943
1 switch heated rear window [window defroster] 61311376445
1 switch fog light tail 61311368893 - blank large switch with no markings
1 hazard light switch 61311372893
1 [fog light] switch cover 61311375984
1 fresh air gille left [ac vents] 64221367385
1 fresh air grille right [ac vents] 64221367388
2 fresh air grille center [ac vents with trim] 64221367390
1 [headlight] grille left 51131930827
1 [headlight] grille right 51131930828
1 heater duct rear left 64221873371
1 heater duct rear right 64221915014
1 [temperature] control unit 64111373214
1 knob temperature 64111367695
2 [sun visor] holder 51161927474 - w/hardware
1 sun visor left 51161917897
1 sun visor right 51161917900
1 check unit 62141368952 - display unit that goes in front of sunroof
1 outdoor digital clock 62131377803 SOLD
1 covering digital clock 62131367686 SOLD
1 interior rear view mirror 51161856356
1 front headliner cover 51441873479
2 door handle inner right 51211926306
1 covering apron left 51431872851 - A pillar cover
1 covering apron right 51431872852 - A pillar cover
1 [plastic] covering inner left 51711880547
1 [plastic] covering inner right 51711880548
1 [steering wheel] trim panel upper part 32311154272
1 [steering wheel] trim panel lower part 32311154274
1 switch turn signal, dip-dim controller 61311377987
1 wiper switch 61311377979
1 side panel [fender] right 41351961672 - excellent condition
1 trunk lid 41621959569 - has holes from sport spoiler
1 sport seat cover [can't tell left or right] 52101904819 - part number says 52101934681 but cannot find
1 molding lower [front windshield] 51311817451 - comes with left and right corner moldings
1 molding lower [rear window] 51311817452 - comes with left and right corner moldings
1 flasher parker left 63131386609 - bulb but no lens cover
1 flasher parker left 63131367902 - bulb but no lens cover
1 toolbox 71111119997 - tool box tray with holding strap and screw plug
1 trim panel lower right 51451875862
1 trim panel lower left 51451900643 - main trim panel under steering wheel
1 glove box 51161884591 - complete with locking mechanism, hinges and flap
1 cover for sliding roof motor 51441864536 - for headliner cover 51441873479
1 [e-brake] protection cap 34411153534 - rubber cover
1 [trunk housing carpet] panel wheel housing left 51471875844 - carpeting
1 [trunk housing carpet] panel wheel housing right 51471875844 - carpeting
1 [storing partition] lower cover 51161885346 - center console
1 [storing partition] upper cover 51161885340 - center console
1 [storing partition] vent cover 51161875613 - center console
1 [headlight] covering right 51711917668
1 [front license plate holder] protective molding 51111882988 - for euro bumper, cracked but repaired
1 storing partition net 52101931792
1 moulding roof left [roof trim] 51131817443 - slight bend from prying
1 moulding roof left [roof trim] 51131817444 - very minimal bend from prying
Re: FS: MANY Parts - Parting Out 87 535is 5spd
Why cut it up if it doesn't have any rust??
mr_biased
Post by mr_biased »
The rear was hit and previously, salvage titled, repaired [kinda poorly]. The car was about to be a project car but things got turned upside down so now it's out to save others.
Archaus
Post by Archaus »
Interested in:
2 cover loudspeaker 65121367715
Also looking for radio antenna and motor
shipping to 07090
mr_biased
Post by mr_biased »
Loud cover speakers just sold. Sorry but the radio antenna and motor is broken.
MajorBob
Post by MajorBob »
battery hold down 61211353680, also the antenna nut and associated grommet 65221959935
Trunk mat/carpet - 51471917743, and good black floor mats? thanks!
-- Added May 04, 2018 5:16 AM --
also, the two Pliers from the tool kit 71111103092 and 71111103091 and that silly little blue cloth 71111115810 :laugh:
b29fe
Post by b29fe »
Driveshaft Available?
The car is overall clean, non-rusted and solid condition (sans the rear end damage). It is a perfect candidate for body parts donning.
Sander is a good guy; I was just down there yesterday reviewing some of the body parts he agreed to cut out for me to use as grafts for the M535 (even if it is causing him some headaches more than anticipated). I'm getting a bunch of needed pieces that will help out in the near future.
TurboE28
Post by TurboE28 »
vinceg101 wrote:The car is overall clean, non-rusted and solid condition (sans the rear end damage). It is a perfect candidate for body parts donning.
Darn, if I would have known you were there. I picking up parts tomorrow. Going back soon?
Maybe next week at some point or Sander my come up on Monday. Nothing decided yet.
3toedshewie
Post by 3toedshewie »
Hi, interested in the sunroof panel. avail? shipped to 33432?
where you located?
thanks,
JosueBencito
Post by JosueBencito »
I need the black trim that runs along the door opening from the top to the sides and holds the headliner in placed. each 4 door opening has this trim. I don’t know the right name for this part.
please let me know if you still have them for all four doors. If it’s ok , you may call me at 909 996 8283.
Also, do you still have the fuse box? I can pick them up from your place. I am coming from the Inland Empire.
Thank you
rubix_cube12
Post by rubix_cube12 »
Would you happen to have the drive shaft flange? Part number 33411129859
edonce
Post by edonce »
need a hood ? and doors ... are any of these available?
thugginrobby
Post by thugginrobby »
5spd?
jameson17
Post by jameson17 »
how are the floor boards ?
BRRV
Post by BRRV »
How about the selector rod, 25 11 1 220 910? This is the connection piece from the shift console to the gearshift rod joint. The transmission end would need to be smooth and unworn.
p2592b
Post by p2592b »
How much do you want for the front seat belts? Can you send me some pictures of them, specifically where they bolt to the seat brackets? im trying to see if they will work for the e34 m5 seats I’m installing in my car.
Archaus
Post by Archaus »
If your shift knob is the doorknob-style, mushroom-shaped, leather covered knob, I'd be interested.
41magfan
Post by 41magfan »
cluster ? "a" pillar, driver side ?
Frostedd
Post by Frostedd »
How much would you want for both the headlight grilles?
lenaxia
Post by lenaxia »
Is your radio wiring harness still available?
Also want the driver's side b-pillar.
afireinside1988
Post by afireinside1988 »
I need front driver door glass and rear windshield. Do you have these for sale? Someone vandalized the shit out of my car and I'm looking at about $1000 just for the two pieces. Thanks in advance.
MaxACalgary
Post by MaxACalgary »
Hey, wondering if ecu is avail, its part number, and if it is known good.
I'm located in Calgary canada, t2e 0m7
breckski
Post by breckski »
Hello,
I am looking for trunk hinges and torsion bars from a 535is or M5 e28.
I know you stated that the car was hit in the rear but I was wonder if these parts survived?
thanks
MajorBob
Post by MajorBob »
How about pn 72111860143? Its the outboard seat-belt mount cover. I need 1
ricko13
Post by ricko13 »
Please PM me about the Sunroof Motor if it's still available!
red1378hat
Post by red1378hat »
Hi, I'm interested in the 2 rear headrests w/brackets 52201929943 if available?
sbuontempo
Post by sbuontempo »
Hi
Do you have a/c compressor for 535i?
Thanks
Sab
Bimmerod
Post by Bimmerod »
Looking for the ebrake cover with good bristles in Black
Let me know,
Bimmerod
:cool:
