CLOSED
Luk_L95
CLOSED
Post by Luk_L95 »
I have a running 524td parts car in the shed.
the engine will be parted, as I am located in Austria, Europe shipping is not available for block, head etc..
Just send me a message what you need and we can work something out.
LuckyHenriksen
Re: Parting M21D24 Engine
Post by LuckyHenriksen »
PM sent!
2mAn
Post by 2mAn »
Any Injection pumps?
loveoption9
Post by loveoption9 »
Hi I've got some injector pumps. I have one of unknown condition, and probably another that is installed on an engine that failed but, I know the pump is fine.
The unknown one is available now, the one in the engine would need to be removed, which might not happen for a month or two.
I'd like $200 for the unknown and $400 for the one I know is good.
I will be having quite a bit of parts available soon, as I have two of these engines, one with a bad head and one with burned piston that I was going to merge, but found a donor 524td instead, It's kind of a nice car, straight body, and some odd bits missing. I am reluctant to part it out as it drives nicely, the odometer says 300,000k, but the engine had $7K worth of work 15k miles ago, half just for a new head. I have a beautiful Vixen motor home that desperately needs a powerplant. And so it goes.
gadget73
Post by gadget73 »
If the pump isn't missing, but simply leaky or whatever it can likely be rebuilt. Its just not cheap. Mine was working but sprung a leak. I elected to have someone that knew what they were doing fix it and it was like $1200 for that job but it came with a 2 year warranty. It ended up getting a re-seal and some of the governor parts inside were replaced.
Luk_L95
Post by Luk_L95 »
Hi,
injection pump is still available and worked when removed.
https://www.ebay-kleinanzeigen.de/s-anz ... 3-223-7482
Luk_L95
Post by Luk_L95 »
Injection pump sold
Luk_L95
CLOSED
Post by Luk_L95 »
Everything else sold!
