Drive shaft vibrating from 1st to 2nd gear
Every time I take off from first to second it feels like my passenger seat is about to fall out of place , but my drive shaft is whats actually vibrating. Opened it up before and checked it out took it to a couple of mechanics and nobody knew what was wrong with it. Is this a serious problem? and what should I do to repair it. Any suggestion would be great.
Thank you
Thank you
Yeah, U joint(s). My front one got stiff and did that. Eventually I could feel vibration even at 70 if I floored it. I broke all the rules, matched a different front half with my existing back half and never looked back for the next 130K til I sold it. It wasn't perfect new car butter smooth, but not bad at all. And nothing like it had been.
I just had my driveshaft replaces due to bad u-joint. New guibo, csb, driveshaft ... all installed per Bentley.
I now have a vibration similar to this. 1st gear starting out, it vibrates then goes away as RPM climbs. Same with second gear though the vibration is less. 3rd, 4th, and 5th are smooth without noticeable vibration.
I am guessing this may be related to bad subframe bushings (which I know are bad) and diff mount (which I am guessing may have been beat up by the bad driveshaft). Dogbones are new.
Do this sound reasonable to you guys ?
Also look at the UCABs.shwaa wrote:I just had my driveshaft replaces due to bad u-joint. New guibo, csb, driveshaft ... all installed per Bentley.
Henry
No vibration in steering at all .. zero .. zilch. Is this still something to look at ??cleeves wrote:Also look at the UCABs.shwaa wrote:I just had my driveshaft replaces due to bad u-joint. New guibo, csb, driveshaft ... all installed per Bentley.
Henry
Did a better test yesterday. The vibration is 25 mph and below for me. It is there whether I am in 1st, 2nd, or 3rd gear as long I am below the 25 mph threshold.
I also only have the vibration on acceleration. No vibration coasting or engine braking.
This is a brand new guibo, driveshaft, and CSB.
Interesting little gremlin !!
Re: Drive shaft vibrating from 1st to 2nd gear
Anyone ever figure out what this was?
Usually u joints. If your driveshaft is still original, it's been on borrowed time for a while.
Check the trans mounts too, if they're collapsed it affects the driveline alignment.
Will do. It’s on the list now
