At one point I believe I thought arp made both head bolts and head studs for the m30 ending. However, at this point I'm only seeing head studs for the engine.... am I mistaken?? Are head studs the only option available for the m30b34 at this point or should I look more for head bolts?? If anyone knows where I can head bolts please let me know.
Thank you.
Availability of head studs vs head bolts
Re: Availability of head studs vs head bolts
Why upgrade from stock head bolts to aftermarket bolts? Won't the bolt yield more easily since it is already under tension throughout the length from the get go? Also, you don't know if the thread tightening torque is actually being applied to the head or just the threads at the bottom...
I've only heard of the studs, but they do (slightly) interfere with the stock valve cover sheet metal baffle on m30.
i'm making 460tq and stock bolts have been working fine for me and on an abused engine too.
they are at 68ft/lb btw.
