E23, E24/28, 745i parts
cjarvis99
Post by cjarvis99 »
Good morning,
I sold my 745 last year, and the M635 in 2019. Below are parts that I've had on the shelf that need a new home. Some new parts. Most of the used parts were working parts pulled from the 745 I sold, dates and mileage noted. The other used parts were spares. I can post pics if interested. Location is Troy, MI. Prices do not include shipping.
- NOS K27 Turbo - $500
- M106 ECU/TCU 0 261 200 013 - $500
- M106 AFM Bosch 0 280 203 022 - pulled from car in 2008 - $150
SOLD
- ZF 4HP-22 transmission and P1 torque converter. Pulled from car in 2009/63K - $400
- 2.91 non-LSD. Pulled from car in 2015/87K mies - $50
- 4 chrome BMW metric bottle cap wheels, Old Michelin TRX tires mounted. $50
- M106 valve cover. $50
- 3 used E23/E24 Self Leveling Suspension pumps with attached pressure sensors and solenoid valves - $50/ea
- New E24/E28 rear brakes - ATE rotors, Jurid pads, wear sensor - $50
- SOLD - New M106/M30 engine fan Clutch - $25
- SOLD - 2 E23 euro factory air dams, one as original (unpainted) one painted in Delphin. $50/each
- SOLD - 1 BBS replica air dam, painted in Delphin. $50
- SOLD - NOS M106 AFM Bosch 0 280 203 022 - $250
- SOLD - M106 fuel injectors. pulled from car in 2010/65K miles - $50
- SOLD - New complete set of E23 in dash heating/cooling duct actuators (5) and valves (3), does not include the two under the cowl. - $250
- SOLD - New E23 vacuum reservoir (heating/cooling controls) - $25
- SOLD - 8 cans R12 refrigerant, expansion valves. $20/each
- SOLD - New 4 E23/E24/E28/E32 after market final drive half shaft boots (300526) - $50 for the set
lateforlunch
Re: E23, E24/28, 745i parts
Post by lateforlunch »
PM'd
LarryM
Post by LarryM »
PM'd
Pavel
Post by Pavel »
PM'd
cjarvis99
Post by cjarvis99 »
I thought I would do last call here before listing these last items on ebay. New prices are close to what I'd ask on ebay.
- NOS K27 Turbo - $300 (was $500)
- M106 ECU/TCU 0 261 200 013 - $300 (was $500)
- M106 AFM Bosch 0 280 203 022 - pulled from car in 2008 - $75 (was $150) - SOLD
Also found a couple toolbox items I wont use.
- BMW Rear Sub-frame Bushing Master Kit $50 - SOLD
Same as: https://www.pelicanparts.com/More_Info/ ... L-TOL-3026
- MityVac Vacuum pump Kit MV8500 $40
Same as: https://www.skf.com/mityvac/products/ha ... its/mv8500
PM me for pics of the actual parts or tools.
Thank you.
austin8753
Post by austin8753 »
Craig,
sent you a PM. thank you!
Austin
CanadianMiniFan
Post by CanadianMiniFan »
PM’d regarding the ECU
